1100 lumen 16340 klarus Mi1C Resistor Mod
Thanks.
I was careful unscrewing the plastic, but nevertheless I slipped and ripped some resistor and some other element.
It’s funny to see strobe running with moonlight level .
OK, will have to repair. But first another question:
Without split ring pliers, what’s the best way to unscrew the bezel?
I tried tweezzers, couldn’t do it. I tried friction, didn’t work either.
I can glue it to something and then polish the glue off but that’s quite a lot of work…
You just need a cheap blunt nose set of needle nose pliers usually a dollar at most hardware stores.
The nose is rounded except where the pliers contact, it’s ground in a D shape. They fit in the round slots on the bezel.
A cheap pair of these should work fine with a blunt nose.
https://www.ebay.com/itm/Precision-Beading-Pliers-Tool-Kit-Set-Jewelery-Design-Bent-Nose-Cutting-Needle/162575785598
Bought model 359A a few months ago, tip diameter is less than 1mm. Handy and sturdy enough.
Cheers
Managed to unscrew the bezel with a grinding stone. Pressed the bezel hard against the stone and the friction was enough.
Unsoldered leads, no problem. Couldn’t unsolder the ground though. Too little power? I use a large screwdriver type bit, 410 °C, 50W iron. Is the iron too weak?
I weakened the connection, moved the wire a bit to the side with the iron and then cut with a knife.
I re-soldered one of the elements that I ripped off. Now I think it was not a resistor but a capacitor. That thing is TINY.
I moved the other into place - it seems I bent the legs, but haven’t broke them (not sure).
What is the simplest way to test if it works now?
According to my plastic calipers the lens is 13.1 mm.
I wonder if we can find AR coated replacement…
I don’t know if you will find one in that size but this one could be sanded down to fit.
https://www.fasttech.com/products/0/10001022/5422711-14mm-ar-coated-glass-lens-for-led-flashlights-diy
I just sanded down a lens the other day to fit my triple xpl DQG 4th because I couldn’t find the size I needed.
Best 16340 batteries I have tried so far. I ran a 3 amp test on them and I got 400mah to 3v. Would have been more if I had lowered the cut off voltage to 2.7v. Thanks for the recommendation CRX. :+1:
I still have some trustfires on the way to test when they get off the slow boat.
Thanks, but this light has only a plano-convex lens.
I failed to find any AR-coated one that could fit. Though I may try harder at some point….
I’m guessing you have the aluminum version. The Ti and Cu version has a reflector with a AR coated glass lens.
Cool, would be nice to see how the TF performs too :+1:
Yeah, I have Al. It’s uncoated plastic. I’ll see, if I get deeper into this light I may get a Cu/Ti one or ask Klarus if the are willing to sell me a coated one.
Thanks for the good news.
I finally got the trustfires in off the fasttech slow boat. I got a little over 500mah at 10 1/2 mins at a 3 amp discharge to 3v.
The trustfires hover around 3.55v at a 3 amp load and start down from there.
Fasttech is the same place HKJ got the batteries he tested from.
Seems that its the same battery and nothing has changed. Best 16340 out there for high drain devices. How long they will perform at this level, time will tell.
:+1:
A warning for when you remove the driver retaining ring !
Both Argo and i have stripped parts off of the battery side of the driver when unscrewing the black plastic driver retainer ring!
Be careful not to stick the needle nose pliers too deep into the driver retaining ring when you unscrew it !
