No, just clicking forward: off-high-low-strobe-off-high-low-strobe-off-high etc.
The next iteration: dedomed ‘Mitko’ XP-E2 R3 0D on a Noctigon, glued in with AA-Adhesive (because I can…)
Surprisingly, the output in flood has not increased, still 130lm. But for the rest:
-infinitely better tint (0D’s dedome pretty nice)
-infinitely better beam (took care of most beam artifacts, and the XP-E2 die just looks better)
-better throw (I measure 24kcd, which is about half of the max that you can get with this size lens)
I can’t tell without unsoldering wires, next time I have it apart I will measure current.
I can have a guess of course for a ballpark number: 130 OTF lm in a zoomie may be 180 ledlumen, roughly times three gives current, so 550 mA ?
Low gives 25% the output of high, so maybe 130 mA ?
As requested, the current measured over the ledwire:
Next little step:
I beefed up and shortened some wires here and there and it did not help the output much.
But what are those 1.2 Ohm resistors doing in the led- path?, that is not very BLF!
Ah, that is better, how’s the current now?
That helped, just doubled the current, 1.4 A is quite right for a XP-E2 on a Noctigon, with average heat path.
I guess I will have new output and throw numbers, re-charging the little light now….
I’m having a lot of fun with this light sofar! Budget lights rule once again!
Thanks
And I’m sure if you seriously go into minimising all resistances, and solder in an Efest IMR battery, you get 2+ amps to the XP-E2 and more to lower voltage leds.
<5dollar-mini-zoom-USB-rechargable-flashlight, dedomed XP-E2 R3 0D on 16mm Noctigon, focusshift from thicker Noctigon repaired with extra o-ring between the two pill-parts, Keeppower protected li-ion, some wires shortened, some a tiny bit thicker, current limiting resistors bypassed:
Output in flood at 30 seconds with fully charged battery: 190 lumen
Throw at 30 seconds with fully charged battery: 38 kcd.
The throw is pretty close to the maximum that I have got for this lens (43 kcd in an Ultrafire AT-007, same type lens).
