Just remember that your leads will have inductance, capacitance, and resistance. In many cases these things could mess up the results, thatās why the device is built the way it is rather than like a DMM.
In circuit testing can be pretty hit and miss. It really depends on how the circuit is laid out, but youāll often find scenarios where you canāt measure things properly in-circuit. OTOH youāll often find things you can measure in circuit, so donāt let me stop you - just be aware of what you are doing and whether other components may skew your results.
Depends upon what you are testing. Trying to measure a 30 pF cap with 200 pF of test leads or a 20 milliohm resistance with 1 ohm of test leads isnāt a good ideaā¦
200 pF of test leads is nothing when measuring a 10 uF cao. 1 ohm of test leads is nothing compared to a 1k resistorā¦
So let me get this straight: I can stick a component anywhere in that ZIF socket, in any orientation, and it will tell me the pinouts? Would I have to worry about frying anything accidentally?
Thatās pretty much how it works. The ZIF socket pins are labeled with 1-2-3 with multiple pins on the socket assigned to a 1/2/3. i.e. you canāt stick a device into two pins labeled ā3ā.
The max test current is 6 mA so no worries about frying anything.
I went to the local surplus store and tested a bunch of their devices. The only thing it has problems with is big triacs and SCRs that need more than 6 mA to turn on. Also inductors less than around 20 uH.
Polypaks! Your advanced state of geezerdom is showingā¦ young whippersnappers these days donāt know the simple pleasures of PolyPaks. I wonder how many floor sweeping brooms they went through?
Went ahead and ordered, said it could take as long oct 22 but I dont really have any immediate need for it so oh well, Iāll probably forget about it by the time it gets here and itāll be a nice little toy.
WTF is a PolyPack? Google image returns a random assortment of not-even-remotely-related crap.
So I got mine yesterday, in reference to your mod in post 14, sounds simple enough I should be able to figure it out but just in case is there a diagram / labeled pic somewhere to show me what parts / pins / traces are what?
I could do tha however I donāt have that large a selection or parts to test, would you (or anyone else) be willing to mail me a selection of different components (Iāve got resistors and diodes covered, what I could use are SCRās, inducers and large (2000-200,000uf [the claimed limit]) capās
Iād have picked one of these up by now but for the ridiculous excess of options, and not knowing which ones will be upgradeable as the firmware continues to improve. The eevblog thread on them isnāt much help either.
