Well, to each their own I guess. As I’ve said I have small hands, still I like the finger choil on my (15cm open) Malyshev Gnome.
For most tasks it’s enough of a blade, go and check how much length you really use on a knife.
If you cut open bread rolls every day then you might need a “full” blade though.
Anyhow, that’s why I said, try it yourself if you dare to probably change your mind (as I have).
I even added a finger choil to an Enlan knife when I tried another material for scales.
If it had better balde steel and the clip closer to the butt of the handle then it could be my edc knife…
Maybe you will see your initial opininion was right, so what?
You have a good knife to gift to someone who might like it or you just store it in your toolbox/car as a backup knife.
It’s not a Sebenza by all means…
By the way, it’s slightly arrogant to lecture someone this way who only told his opinion.
You feel one way about it, I disagree, yet I don’t say you’re “wrong”, you just see things different.
And with your sayings above you tell that you don’t even have to try it because you know it already without trying.
Very smart, I’m envious. Kinda.
The Kizer Domin Mini hit the mailbox today. Excellent little knife. Was clean and lubed nicely from the factory. Good lockup, 35% or maybe 40%. Blade is perfectly centered. Wickedly sharp as well.
I couldn’t pass it up. I have never had a knife that uses Bohler N690 steel. I don’t really know anything about it other than what I read on the internet about it. People seem to like it and compare it to VG-10 steel. Think I read it was a Carbon Enriched Stainless Steel. Time will tell how long it holds an edge and how easy it is to sharpen.
A few other knives are in the picture as well, just for a comparison. From top to bottom. 1 is a Kershaw Leek. 2 Medium sized Honey badger. 3 is a Bestech Pebble. 4 is the mini Domin, and the last one is a Kizer Begleiter.
I really like the size and quality of the mini Domin. Is it worth $55? Yes I think so. It seems to be a solid knife.
It is just a great little knife. If you got the extra money and it won’t get you in trouble with the better half, grab one. I think you would really love it. Of course you don’t have to get it in blue. I just have this weird thing in my head where if I see a blue option for anything, I just buy it. I have no idea why.
Yeah, I’m thinking I’ll like this one a lot. The 2.9” blade on the Mini just suits what I like. The Bohler N690 is a good steel to.
Funny you mentioned your liking of the Blue handles. A few months ago I picked up a blue handled knife off MassDrop <span class=““Drop” now”> and loved the color. Since then I have acquired a few others in Blue.
I’ll get this one in Blue too. It is a nice alternative to the usual Black.
Where did you get yours? Blade HQ??
Edit: This one looks pretty interesting to at $49.95.
The mini pry bar/french fries fork is my test piece for rock pattern and orange peeling.
It’s quite easy to do, all you need is a steel brush mount on a belt grinder or alternatively on a drill press
(if you don’t work at an orthopedic shoemaking or shoe repair shop
It makes the handle quite grippy, it’s surprising that this little surface treatment hasn’t become more popular on cheap knives from China just as anodizing has.
By the way. Now as I have my 120V power supply for anodizing I realize that the best colors are in the low spectrum
Still it’s nice to be able to adjust the current in 1/10V steps, with 9V batteries it was impossible to get matching colors on framelock knives.
I don’t regret to spend the $62
Ok, you’re right, for (bead) blasting you’d need some special equipment even though I’d never blast a blade.
It’s a good technique on handles made of very stainless steel or Ti but every blasted (Kershaw) blade I tried had dots and smudges on it after the slightest use.
Blasting tears up the surface and even “stainless” steels like 8Cr13MoV will get spots.
Only steels used for handles that don’t need edge retention capabilities won’t react like that.
Whenever I get a beadblasted blade I just stonewash it right away, preferably after polishing, that gives a nice “frosted” surface.
