With a 20mm star of even a big 26mm Maxtoch board, and flat surfaces to begin with (that Secruritying led-shelf was rubbish) the layer of AA will be thinner and have a larger surface area, the method could work much better then.
Hi :nerd_face:
Why wouldn’t an Osram Black Flat work on a Regular AMC7135 Driver? , because from the Datasheet the Center pad is Connected with the Negative Terminal of the LED ?
EDIT:
The answer is because AMC7135 Chips Regulate using the Negative Terminal :student:
Cool, he must have done the regulation at the positive side then. I hope that Richard is selling this driver soon (still a pain that his business is in the US, some country with one of the poorest postal services combined with the most expensive international shipping in the world).
Another solution for the use of Oslon leds is the new 20mm non-DTP (but with DTP-level thermal performance) board that led4power is going to sell soon.
I could design real quick a Nanjg 105 compatible p-fet driver, no magic there arenplenty good p-fets, just moonlight will be not as low as with fet+1 drivers
I am sure Djozz will test it it with olson black flat. :+1:
Edit: 16mm versions would be best sellers for sure but if Led4power decided to go with 20mm than ok… For example I can only use 20mm in one model of light and 10 other models use 16mm one.
