✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Dude, some of your coupon codes have expired. I tried the BLF A6 and the Imalent DX80 from your first post links and those don’t work.
This deal for DX80 still works:
I’ll check codes for A6.
EDIT:
A6 code 2017FNL expired, 8a955d still works. For Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 coupon code 76648A works.
I generally try to remove expired deals from the list in first post, but I’m not able to check everything all the time and end dates are most of the time not disclosed and/or change. Some very old coupons still work, others can be disabled and then reeanbled again.
That wasn’t the deal linked in your first post - it was the one for the DX80 for about $208. Nice to see you still have something in there, thanks!
Both are listed - in fact also another one (older one with 2$ higher price but also working).
It’s best to use search function (Ctrl-F in most browsers) and check for all deals in first post.
XANES D25 1650LM 2 x XPL2 LED 6 Modes Stepless Dimming USB Charging Interface IPX6 Waterproof Cycling Headlamp 18650
New headlamp from Xanes with 2x XP-L2 LEDs. It’s now in preorder: first 50 pcs for $12.99, up to 500pcs for $13.59, then $16.99 and final price is supposed to be $25.49.
  • 2x Cree XP-L2 CW
  • 2 Aluminium OP reflectors
  • 1x18650 power supply
  • 6 modes with stepless dimming
  • micro USB rechargeable
  • max output up to 1650lm (with decent high drain battery - Samsusng INR18650-30Q is suggested)
  • weights onlly 80g without battery (2.8oz)
» Jump to First post quick links/deals list «
Good day ,
I can ask for a BLF A6 coupon
I'm interested in 5A color light / can also be version with battery /
For XANE D25, may I know what is the lowest output for its moonlight mode?
Apparently there’s no moonlight if the description is accurate. Lowest setting seems to be ~200lm
This however looks like a nice candidate for modding - I was thinking XP-L HI CW with reflector for throw in one socket and high CRI Nichia with TIR Optics as second LED for close range flood beam.
ThorFire C8s Upgrade XM-L2 900LM 5Modes Cycling Outdooors LED Flashlight
It’s now in flash sale for $12.40 ($16.95).
Offer expires in 3 days and 15 hours.
It’s basically a complete flashlight for the price of a host.
For both:
use coupon code 8a955d
Ordered a Xanes D25 to check it out
Code for Thorfire C8s upgrade please.
I’m curious about this, because it looks almost exactly the same as the dual-LED version of the Boruit EHL0628 headlamp (review of the single-LED version here: Boruit Headlamp Review D10 (aka. EHL0628) - King of the Budget Headlamps?)
(the charging design looks the same, even the headstrap color looks the same; and the pre-order price is almost similar to the price of the Boruit one)
The Boruit product page mentions “L2 beads” (probably mean ‘LEDs’), but doesn’t specifically say “XP-L2” whereas the Xanes one does.
The Banggood Xanes model’s picture of the LED doesn’t seem clear enough to identify if it’s really XP-L2 or not (and it does not indicate “Cree”).
It’s possible there’s an OEM manufacturer for the same type of headlamp/headstrap though…
Too bad i was thinking use it as midnight pee light.
Ya, dual LEDs has more possible ways to mod. You have great idea combining xpl hi and high cri nichia.
Dual led version has poor thermal path.
It is a flash sale. No coupon needed.
For the Thorfire C8.
What is the colour temperature of the LED?
I don’t see it in the description.
Thanks
I would suppose L2 beads means XM-L2 and this is what the LEDs look like in the pictures linked @aliexpress. Whether those are authentic Cree is different matter - they can be some lower bin as those are cheap enough already.
I could not find production lamp with that combination. I like the idea of Nu25 - nice combo with small package, but still would want a single lamp with XP-L HI and Nichia with TIR optics (like in NC TINI) as it would be much better and brighter than used COB LED.
Looks like standard 1A cool white tint.
There are some reviews at youtube:
(this one complains about no waterproof rating - there was no info Amazon but BG it says IPX-8, and was tested - even freezed :smiley: in next video)
