@teacher That was my plan. I was going to do a little research to see want kind of flaws the ut61e has and to see if I kind find more info on MM600. I was going to use them for auto and around the house beside checking battery.
While I was at Walmart I pick up the ONN charger they had in stock.
If you can return it for a full refund without a hassle, then it may be worth trying. When you get it, compare it against a known reference and if itās pretty close, then you can keep it. Otherwise, return it.
If I go through Home Depot it has a 30 days return policy. None of the Klein Tool DMM can be calibrated. My concern is after the warranty period if the calibration goes out iām stuck with a expensive paper weight. Iāve been reading on different forums and it seems like the calibration goes off a little in about a year (not sure if itās true).
I see. Well, there are other DMMs out there in the same price range as Klein that can be calibrated.
If I didnāt already have a DMM, I would have gotten a Uni-T UT61E.
But letās face it, we are splitting hairs here. Majority of these DMMs, even if theyāre off, theyāre off only slightly. For what we do here, these differences in readings would not be significant. So I would not go as far as calling them āpaper weightā.
Since Iām not the only person using it I like to get one that is quite accurate without going over board on the price. Itās going to be used for more than checking batteries.
Most any modern day meter is very accurate. Remember the story of my years old Innova 3320?
For what we do that one is just fineā¦ as are any number of others. But if you want absolute accuracy, and none of the cheaper brands or knockoffs fill the bill for youā¦ā¦
Do like Pete7874 said and fork out the bucks for a Fluke.
I knew that somebody is going to mention to get a Fluke. That why I mention I didnāt want to go over board on the price.
I guess I was asking if a cheap DMM can be accurate as a Fluke and reliable over time (I know teacher is going to mention 3320). If a DMM needs to be calibrated, does it hold the calibration for a long time or does it need yearly calibration?
āāā The following is taken from the link above
For hobby/student DMMs, the answer is no. You donāt have to calibrate it every year. Please take note of the quote: āA long calibration period for the digital multimeter is normally to be advised, except when particularly demanding testing is required.ā. For a 3 1/2 digit battery-powered DMM, most never get calibrated after being bought.
If youāre using a 6 1/2 digit unit, and measuring microvolts to trouble-shoot medical equipment, thatās another story.
It all comes down to how important absolute accuracy is to you.
āāā-
Here is another link that might be usefulā¦.
āāā @Venom
I think the answer to your question lies in how important is absolute accuracy to you?
If your meter reads 4.9998 V or 5.0001 V instead of absolute 5.0000 Vā¦ā¦ is that acceptable to you?
Also be aware, as mentioned in the video & links above; that what I/we loosely refer to as ācalibrationā: does not always include adjustment.
Like anything elseā¦ this appears to be able to be taken as deep as one wants to go.
I have found a few more things on calibration that I find interesting (even if I do not understand most of itā¦ :person_facepalming: . ), so I thought I would share links to them.
They are listed in no particular order of importance. I just listed them as I found them. The ones that are not bold seemed less applicable to the subject āto meāā¦ but I listed them anyway.
I listed so many because I did not have time to read them all right now & wanted to have a reference I could go back to.
There is a lot more to this than I imaginedā¦ā¦
So, without further adieu; let us proceed.
Precision Multimeter Calibration Reference
ā¦ā¦ā¦ This guy said the following at the beginning of his article: āWARNING / DISCLAIMER: If it aināt broke, donāt fix it. Tampering with the settings inside your multimeter will void the warranty, could mess up itās accuracy permanently, risks causing mechanical failure, and could feasibly cause actual danger from high voltages. I accept no responsibility for any damage caused by following these instructions.ā
I know I have mentioned a Innova 3320 meter many times. I am not saying it is a āqualityā meterā¦ in the big scheme of things it most likely is not. BUT, although I do have a more expensive meter, the Innova is just as accurate to 1/100th of a DC Volt as the more expensive meter.
For me this is more than adequate. I am not testing pacemakers, other medical devices, the Space Shuttle, or anything that has to do with life or death. Sooooo, Iām good.
And as I said before, when I received the more expensive meter & a VRM (voltage reference module) as a gift from a BLF friend in the UKā¦. (thank you again Ianā¦ :+1: ); the years old/rough treated Innova and the brand new meter both were right on the money.
Sure the newer more expensive meter has more resolution, it will measure to 1/1000th DC V and do a bunch of other neat stuff such as temperature; that the Innova does not have or cannot do. And all that is pretty neat.
So basically, as far as āI am concernedā; a meter choice just boils down to how much money one wants to spend and the absolute accuracy they require.
And I am far from an āexpertāā¦ā¦ so take that .02 for what it is worth.
But as for me, I am more than covered with what I have.
When looking for a DMM you also have to think about it usage.
Fluke is designed for mains work and will easily handle industrial or outdoor conditions, they do also use very good parts, meaning that the calibration will hold for a very long time.
Second up is Keysight(Agilent). They are very good, but a bit more technical than Fluke and in my opinion not as precise over time.
After that there is a couple of brands that is good and also usable in mains work.
Below that is all the cheaper DMMs, they may be precise, but the safety is not up to industrial mains work, as long as they are used for batteries and other low volt tasks there is no safety risk, but do not take them to a high power environment.
I usual use Fluke and Keysight DMMās, I know they are very precise and I do not have to check them against my references very often (For precision over time nothing beats Fluke).
I havenāt read the whole thing; I just figured out youāre looking for a DMM? Hereās my take on why Iām happy with a cheaper DMM (maybe someone else already wrote something similarā¦).
1) I want to measure parasitic drain, and letās say I measure 20 uA resulting in a self discharge time of 20 years. A 10% error is extremely high, resulting in 22uA and ~18 year discharge time, but nevertheless this is sufficiently accurate for me. Iām interested whether self discharge time is 20 years, 10 years, 1 year, or one month. Thatās the kind of ball park range data Iām interested in, so there is no need for an accurate DMM.
2) I want to check status of my four 18650 cells after using them in a 4S flashlight. Letās say my DMM says that voltage of one cell is 3.657 Volts. Iām not interested whether the actual voltage is this value, or perhaps itās 3.75 or 3.51 Volts; the error would again be fairly large. Even if my DMM is not accurate, repeatability is high; this means that the voltage of my other three cells should be about 3.657 V as well. If this is not the case, then something is wrong with my cell, and I should monitor it during charging and next discharge.
Basically you pay a lot more for enhanced accuracy, and accuracy over many years of use (Fluke), but Iām not interested in absolute accurate values of voltage, current, lux (itās on my DMM). Iām interested in differences in values of voltage, current and lux, and cheaper DMMs are good enough for this purpose.
