This question was asked the other day about the accuracy of the Innova 3320 DMM.
Well I though some of you might find the following interesting.
A BLF friend from the United Kingdom sent me a brand spanking new VC99 DMM and a VRM (Voltage Reference Module). So I decided to test it all out as well as the accuracy of my Innova 3320.
The VRM is programmable to test for 10.0V, 7.5V, 5.0V, & 2.5V… DC of course.
Now please remember, while the VC99 & VRM were brand new; the INNOVA is at least 5 or 6 years old, probably a lot more… and has been riding around in my truck or car for most of those years in a plastic container I got at Walmart. Thru heat of summer and cold of winter too……. in other words it has not had an easy lift.
I’ll just let the pictures speak for themselves…. no adjustments were made to either meter. It was not necessary.
Yeah, I’ve got a couple of different voltage reference boards around. Unfortunately, there is no easy way to calibrate my DMM. I can only tell that it’s off a bit.
That’s to bad. I was lucky, even my cheapos had a way to calibrate them.
I had to re-calibrate one 3320 that I had apparently “un-calibrated” a few months ago to a source I though at the time was accurate. :person_facepalming:
Oh well, live and learn. Glad my buddy sent me this VRM though…….
Yes, very easy. Loosen 2 screws, remove the back, turn it on, hook up the leads, get your little screw driver and turn the “adjuster thing” very slowly till it reads correct.
I then turn it off & on again, recheck, & if all is still good. … put it back together.
That’s it.
~ EDIT: … “adjuster thing” = potentiometer
No. I wish it was UT61E, because that one is pretty easy to calibrate.
What I have is Etekcity MSR-U1000 which is a rebranded Uni-T UT61A. This one has multiple potentiometers that could potentially be used for calibration, but so far I have not been able to figure out which one does what and how they interact together, and because the error is pretty small, I decided not to mess with it. Plus, I’m not 100% sure that my voltage reference boards are dead-on accurate either.
FYI, according to my KKMOON rig (based on AD584LH board), the above Etekcity DMM reads low by about 0.22% give or take, so again, not a big deal for me.
Yeah it is Venom, to be honest I was quite pleasantly surprised.
This one has not been babied at all, I’ve used it on cars, boats, lawn mowers, you name it… plus it has been dropped and mishandled numerous times thru the years. :person_facepalming:
Yup. Someone gave me a link to a technical doc on this DMM, but it was way over my head, so I decided that if it ain’t broke (too badly), don’t fix it.
Yeah that is pretty small Pete, 6/1000th’s. Close enough for ‘gooberment work’…….
I like that “case” your VRM is in too……… :+1:
Now, if you don’t mind; I have a question for you about you picture below…….
Below the Voltage readout & below where it says “Autorange” there is a group of short vertical lines numbered 0 to 40. It appears as a “horizontal graph” that is reading “38”.
What does that represent or tell you/us
The VC99 is the first DMM I have ever owned that had those.
I have no earthly idea what they represent & if it tells in the “manual”… I can’t find it.
Yes, it is certainly within the accuracy range quoted by the manufacturer (+/- 0.5%).
Good question. The owner’s manual does not go into detail about this bar graph. I think it is meant to graphically represent where within the currently chosen measuring range your reading falls. So for example, in that photo, the DMM is in the 4V range, and since the reading is 3.832V, the bar graph illustrates that you are near the upper limit of this range. If your reading was to go above 4V, say 4.1V, the DMM would shift to the next available range (up to 40V), and the bar graph would then illustrate that you are at the lower end of that range.
But those 0, 10, 20, 30, 40 numbers on the bar graph scale are static, regardless of which range you are in, so that is kind of confusing.
Thanks for explaining this. I haven’t really paid attention to how quickly the bar graph updates. I typically check battery voltages with it, where there isn’t much if any rapid fluctuation.
