Built more than 50 Eagle Eye X6’s. Give em away, here and there, sell one or two, down to the one D80 although I have a dozen or more X6’s here.
Oh, to help clarify, I’ve been on the group buy teams and tested prototype lights more than a few times.
Got the D80’s big brother, the F3X , a triple… built it up with a copper pill and re-worked the extension tube to be the main tube, like it a lot in it’s present configuration.
Now, this D80 that’s en-route… seems like a likely candidate for an LED4POWER constant current driver set up for around 9A to an SST-40 that’s sliced and diced. 2400 or so lumens, tight defined hot spot, what’s not to like?
Considering this is a BLF light, I’m surprised forum members approved of such a poorly designed UI. I guess this still makes for a good host if you swap the driver.
I actually don’t remember, seems like we didn’t approve, but that doesn’t mean Lucky Sun wasn’t stuck with a bunch of drivers…
Not so very long ago we had no say in what the UI was like. Members here changed all that, for which the noobs can be thankful. Bad UI’s and blinkies is what caused me to learn to build drivers. Once you know how to do that, you welcome a bad UI.
The group buy started in January of 2015, by September we had samples and were giving the greenlight… 711 members here were on the list with the H-L set-up well known. Price was around $20. I was on the team, my protected cells fit, several other testers also had protected cells that fit in the shorter tube. I don’t use protected cells myself so the shorter tube wasn’t an issue to me then, nor is it now.
Old Lumens, ChicagoX, Wight, Bucket, MattAUS, Comfychair, the movers and shakers that are now missing, AWOL, or have left us altogether. (my memory surely fails to recall more)
IIRC, kronological was in the ‘throwers should start on high’ camp and requested the UI that way. Not my preference but a reasonable UI, especially compared to the original UI; Six modes: Mid2-Mid1-Low-Strobe-High-SOS :confounded:
Still for sale there.
I put a shaved dome SST-40 in mine and bypassed the tail switch. The black centering ring started melting so it got replaced with a smaller white one which isn’t a great fit and not perfectly centered, but close.
Regardless, light does ~6A on turbo with a Sanyo NCR18650GA cell. I think that is about 1,465lm. I actually got around ~200 more lumens when I changed centering rings.
The driver’s retaining ring doesn’t want to budge. I was going to take a look at it but I gave up for now. If I replace the driver I guess I will worry about it then.
