I knew the LowPro was too tight. I looked at that one as well. This ApeCase I got is nice.
Yeah, I thought about using the packing foam the light was packed in, but what (if for any reason) you have to ship it somewhere, or decide to sell the light?
I’m leaving the original foam where it belongs and getting other
The Lens Coat Hoodie 2XL is just as perfect fit as you can get, the protective insert is just slightly larger than the bezel and the hoodie is still very tight to the head. :+1:
Admit it. You miss the days of “toilet plunger” lights
Good to know, KB. Thanks for posting about them :+1:
:+1:
Missed the Fabric Shrink Tube on the battery tubes did ya!
Here’s a couple Glamour shots…
That fabric wrap looks good, KB!
Is it a secure fit once it’s been shrunk down?
Can the ends be singed with a lighter to keep them from fraying?
Can we have a look at the side with the seam?
Indeed I did. Too much going on in the background.
Looks alright. How “grippy” is that stuff?
It must be pretty grippy. I see you have it on several lights!
The stuff is a PITA to cut, went thru a bunch of razors (buy a box of them) during the final trim. Cut it with metal shears a bit over size and then followed the o-ring groove to trim. That is where precision comes in, long enough that when you screw the head and tail cap on, it holds the edges in and not interfere with either of them seating.
No it dosen’t really hold all that tight, so I used some contact glue on the flats, and when I heated it up over the stove burner (think HOT and Fast with Mass when using this stuff) rotating on a wood dowel I shoved thru the tube, it shrunk fast and set the glue almost instantaneously. The heat gun didn’t work well at all, because your heating just a small area, even when your moving it up and down and rotating the tube at the same time, not an effective technique at all!
So with a larger mass area of heat, the more evenly the shrink. I ran thru 3ft of it like nothing, so I ordered 6ft more. I got a couple more Idea’s for it’s use.
Now even when the tube got so hot, it burned the hell out of my hand when I grabbed the thread area of the tube, the cloth was just barely warm. Froze it over night in the freezer, the cloth warmed to the touch from my hand, so the insulation value, is worth it for me, to further experiment with it. What the hell else do I have to do in the middle of winter, in Michigan!
Here is a shot of the seam….
It’s really tough stuff as far as protection from abrasion and the added value of the insulation from heat and cold it’s hard to beat. Grippy? Not like grip tape or knurling, it’s still grip-able, I really like it on the TN42 and SD75 tubes better, my 2 GT’s are just show (off) piece’s, WOW look at that big sombitch, then you turn it on ohhh/awww back on the shelf it goes! Not that I would ever use it for Work or Lug it Coyote Hunting/Ice Fishing! :person_facepalming:
Yeah, that’s a bit much, considering the hassle you went through.
It looks nice though. :+1:
I’m sticking with the neoprene sleeves
Nice!
KawiBoy I did a summary about the shrinking tube in the GT support thread
I hope you don’t mind
Joe
Hi sorry for digging up an old post, which bag is the one in the above photo?
Thanks!
