My idea was just about 1 powerbank as I wrote, as almost every 10Ah + nowadays can deliver more than 3A. You have more than one usb port in the single powerbank and also you can use Y cable to use just powerbank to its maximum rated power delivery. And the cells would all be charged as it would one input so always parallel charging. With lab PSUs it is not uncommon to parallel them to double to Current or put them In series (not this case obviously) to Double the voltage
With my phone I cannot post images but this was the idea
Ahh, I see. Ok, thanks David.
Not that I intended to use primaries, but the thought occurred for a second, (based on someoneās earlier post) that adapting a holder for primaries might be useful in a pinch or for the non-lithium-ion initiated. The idea of a carrier was short sighted however; using primaries would also introduce problems related to someone mistakenly trying to recharge them using the 4056 since it would see the voltage range for Li-Ion cells and, it seems, provide a charge current, yuck :confounded: :person_facepalming:
You have to consider not every traveller has a 10Ah+ (letās stick to capacitiy, so 40Wh+) powerbank. Means it has to be large enough to fit 4x 18650 cells and weight around 300g if itās made of plastic.
Most can deliver 1A, some have only one port wich can deliver up to 2A.
Even power plugs only deliver at best 2,5A.
Would it be possible to use a light pipe so that the LEDs would still be mounted in the base but the light would be emitted downwards like a traditional lantern?
@DBSAR
Unfortunately photobucket did change the policy. So from 1st of july 2017, no embedding of images on third-party websites, such as personal blogs and forums, is possible for free anymore.
They sell this function now for $399/year.
So is it possible to reupload the pictures to a fair image hoster?
Now the thread has raised to 12 pages, what speaks for your project. Iām very curious about the result too
Any news for the crowd?
I think the current lantern offerings out there are sorely lacking. With the thought and planning that has been demonstrated by this group for the Q8 and the BLF GT alone, i think a fantastic lantern could be made.
