Actually… I’m also interested in that Shengjie 3 XHP70 LEDs… are those really 12000 lumens?
I wish I could see the beamshots…
I want to see those beamshots too and that driver that they use in it that’s going on sale soon.
Shengjie 3 XHP70 LEDs is very bright, at least 11000 lumens to 12000 lumens, but it gets too hot in 10 seconds… The brightness will step down to Mid mode very quick. We do not recommend triple XHP70 in this flashlight.
3x XHP50 performs good with this flashlight host. The brightness is around 7500 to 8000 lumens and the flashlight can handle the heat well.
I will do some beamshot comparison tomorrow night. triple XHP 50 VS triple XHP70.
Ric
Any beam shots yet? ETA for the 32mm 5A / 6A driver for the triple?
Is the LED on a shelf? Or is it hollow?
Following this thread.
Why not sell hosts of this lights? I am pretty sure plenty of guys here would take them, and you don't have to worry about warranty issues
CNQ used to carry the BTU Super Thrower and the Shengjie 3XU2-X3. A LusteFire 3XU2-X3 will work as a 3X plunger host.
I bought a LusteFire 3XU2-X3 for a song and I’ll be using that as a host. I just need a driver and I’m good to go.
Ric-CN
I got stuff in my shopping cart but have no valid coupon code to use.
When I try to use the coupon code “STR01VTZLV86T”, I get this message. The coupon code “STR01VTZLV86T” is invalid. It either does not exist, has not been activated yet, or has expired…
I registered today on your new website and haven’t gotten an email yet with the one coupon bound to my user ID. There is also no coupon in My Account / My Coupons either.
Thanks Ric-CN for renewing the coupon and feeding my lumen addiction. :bigsmile:
Hi,Ric-CN
for me too I registered Yesterday on your new website and no coupon bound.
+1
and i already made a small order few weeks ago, when he promoted the code
HERE is the picture of the deep reflector
This is a great light. Here are my first impressions of it: It has a great big fugly head (some-one else’s opinion) - which has the best cooling effect of any of my 20 torches, it also houses the biggest ‘single emitter type’ smooth reflector that I have seen in my short career! I think the torch is putting out 18W and I took it for a walk around the park tonight. It ran at high output for half an hour and was only luke warm to the touch…Congratulations to Mr Ric for the outstanding ventillation.
The torch is very bright and the beam is long, similar to my fenix TK-75 but a little less spread. The fenix cost me $220 Australian but this one only cost $70!!! I compared it to my Ultrafire C12, Yezl Y3 and the Sky Ray King XML2 triple, - the Yezl and Fenix are in the same paddock and leave the other two contenders in the back-blocks. When I shon the beam onto a nearby wall the pattern was different to the other (XML’S) I have. In the centre of the bright spot there is an impression of the four separate emitters mounted on the XHP die, and this impression seems to be pinkish (I’m colour blind but it’s an odd colour). When I look at the impression on the wall I can see that two of the emitters are much dimmer than the other two and I have seen this phenomena on another torch that I had repaired, with three XML’S in series. It was originally driven with only six volts instead of nine - the first two emitters shon brightly but the last one only flickered dimly. However this observation could just be a coincidence and it is only my opinion that the BTU STR-01 could be driven a bit harder. Further study of the Cree datasheet and some experimentation could reveal more information over the next near few months. I have absolutely no intention of modifying this torch because it already punches above its weight.
The BTU STR-01 is a very lightweight torch considering the size of the head and when the extension tube is used (the XML2 version has an ‘optional’ extender which I strongly recommend purchasing for a few bucks) it fits comfortably into one’s hand. I’m afraid it is very uncomfortable with just one battery/tube as there is not enough room for a large hand. One further observation of the tubes is good news because the standard 26650 battery fits perfectly both lengthwise and in the diameter, i.e. the batteries don’t rattle.
One thing I don’t like all that much is the tail end switch. The action is very tight. The modes are changed somehow but there are no instructions - I just use it on high. The tail cap switch housing is made from a material unknown to me, it appears to be galvanized iron but could perhaps be a sand-blasted piece of aluminium, but either way it is a grey colour instead of black like the body or chrome like the ring on the head. Of course this is just cosmetic and doesn’t worry me at all because I’m a rough and tough outdoors type bloke!
The threaded parts are difficult to get started but once the parts engage the threads are of a good smooth fit and finish and tighten well. The seals on the battery tubes are red and the first time I threaded them I pinched one as it skewed itself out of the seat.
Batteries do not need to be anything special, I used some red ones that are marked as 7200mAh but yield about 2000mAh mine are the protected type that you can buy from China for about $5 Australian. I cant tell you how long the light will burn for, because I haven’t owned the torch long enough.
I was motivated to say a few words about this light because I heard a bloke knocking the design on aesthetic grounds on another forum. I thought his/her comments were trivial considering the working potential of the torch.
I received mine after three weeks - which is more ‘hare’ than ‘turtle’ these days. I am really happy with my purchase form EDC Flashlight and in one foul swoop I have just superseded 70% of my LED torch collection. I give the torch a score of 7.5/10 and a value score of 9.5/10
Hi Ric-CN
When you are ready to sell 3xXHP 50, and when they beamshots photo?
So a XHP-50 light can throw well??? Wow. How easy is it to make out the "clover" from the emitter in general use conditions?
Wow did Ric go MIA? I’m also interested in beamshots. If he makes the triple XHP70 available then I wouldn’t need to build one myself
What is the verdict on this light?
It would be possible the STR01VTZLV86T coupon code period extended? Smile
unfortunately expired…
