another thing to consider: It is almost impossible to buy a genuine TP4056 board. I once attempted to do so and among some 10-15 purchases all that arrived were fake/copy/clone boards, not a single genuine toppower 4056 IC. Some of these were reported to not be terminating correctly.
this is the datasheet for the genuine tp4056 which was tested by HKJ
yes purchasing a complete board seems like the easiest solution
but what you purchased seems to be only the balance board with 62 Ohm drain resistors, that will equal to some 65mA balancing current per cell. That means that if the charger supplies more than needed voltage for your cell pack, the balancer will be able to dissipate only 65mA x number of cells leaving the pack probably vulnerable to overcharging. I would go with a full BMS, they are also quite cheap for your pack specification.
@vex_zg - I haven’t built in the balancing board, I just came across it while searching for cheap chargers.
@ryansoh3 - Well, I built this speaker with a bit of an addition - I made it 5cm higher and packed all in what I needed.
Battery, charger, 12V Power-Supply, Amplifier, USB-Charger, 2 isolating transformer so you can charge a device and also listen music with it
This speaker can be charged with 230V or 12V (Car) and runs on 230V, 12V input or the internal battery.
