I went out and tested 3 aspherics, 1 TIR and 1 "reflectored" thrower so everything but the TIR was very focused and the TIR was reasonably focused.
I tested each light at 5m, 10m, and 15m.
For the light that many have, the Uniquefire HS-802 (mine has a tailcap reading of 1A), I got very similar reading....33,925 at 5m, 33,000 at 10m, and 32,800 at 15.
The worse case (variance) was with the TIR. I think that's more operator error. At 15 m the beam is much more spread out and it's probably easy to miss the very hottest spot. The variance there was 18%. I'll do that over sometime just for practice to see what is needed to get less variance.
I tested 3 aspherics with the variance ranging between 4.5% to less than 1%. With these lights the 5 m figures are suspect (too high). After everything settles in at 10m and 15 m the variance is very little.
As far as actual numbers (just for information junkies) the Ultrafire BJ08A with 18mm aspheric was approximately 6,300 lux. A 30 mm aspheric I have was approximately 16,000 lux and the HS-802 with a 38mm aspheric was approximately 33,000 lux which was about the same as the reflectored model.
I think that's because of a very good reflector, maybe slightly larger than the aspheric, and a very crude aspheric (due to my grinding). I like it just because I like the narrow (no spill) beam.
I've learned that once you understand more about what you are testing and get a bit of practice using the meter as well that the results can be pretty consistent.
I've also learned that you can't really look at a beam and guess at the lux. I had one aspheric that threw well (but I don't have an area to check out its ultimate range) and I had a bit of tape on parts of the edge to get rid of some minor artifacts. When I started testing both with and without tape I saw that the tape was substantially reducing the lux numbers (and therefore took the tape off).
I also question the overall (low) numbers with the 30 mm aspheric. I'll retest that whole series as well. It was starting to rain and I had to hurry. It should be closer to the 38 mm aspheric than the numbers I got.
