I have pretty much at least a couple of all those 18650 5v usb chargers mentioned. Atm using OP’s version as my edc and it will sometimes just stop charging my phone for no apparent reason. This one is more ‘automatic’ in a sense as it can detect when i unplug my phone and switch off. Charging via mini usb seems to work ok. Just wish their was something with more than one battery bay that is reliable. Will take a look at the hobby king suggestion
Does the ML-102 fit the blf favorite 18680 xtar? (edit: actually 68.5mm, but who's counting?) I have a few repurposed ipod chargers (cellboost irecharge IPR3) that just happen to have USB-in, USB-out, and takes 18700 with some soldering, not worth the hassle to do it again. Would have gotten the ml-102 if i'd known about it earlier.
How efficient would that setup be? Say a 10000mah 7.4v lipoly with that adaptor? How many watt hours are we talking compared to 4x18650 on one of those ebay boxes (70-80% efficiency). Video at the link you provided looks pretty convincing. cheers
I’d prefer the charger that wouldn’t need assembling (putting a battery in) whenever device needs charging. but since ML-102 has so many positive feedback I’ve ordered one and I’m waiting to receive it.
I just received a 1s4p charger with an adjustable output current today (check out #170880896962) and I’ve been charging individual cells up in it while powered from my ML-102 (don’t ask why, lol). So far so good, the 1s4p charger has been terminating early at around 4.083V.
Will do a couple discharge tests from it to see if it will do low voltage cutoff correctly, if this doesn’t die in a month’s time like another BLFer’s experience from such charger boxes, I’ll be a happy camper
I have the 'same' pack and found that my batteries died very quickly while sitting and waiting to be used.
I put in 4 freshly charged Flames and let it sit for almost 3 weeks.
When I tried to turn it on I didnt get any of the lights on even after pushing that button inside. I tested the batteries and found a low voltage (it was a couple months ago now).
Just wondering if you'd seen the same thing?
If I put fresh cells in and don't press the button would it last longer?
It dose look good:
Light weight
well constructed (physically tough)
can run a single battery without big bulk
input and output (assuming both are good: CC/CV input and protect for output)
Takes 18700 (protected 18650) cells
But it’s not enclosed is the only thing.
I’d be using it for campers, perhaps a water proof box that is both waterproof and can have wires coming through it’s lip/seals… hmmm that might be hard to make work. Perhaps a bit of velcro strip to hold batteries in place while jogging or falling.
Yes, if it could take a solar panel charge, while velcro held the bat in place, while inside a waterproof storage box, yet stilled wired to be taking that charge, while in a side pocket of my backpack = would be perfect
when you’re camping you’re willing to spend a few more $$ to ‘get it right’, but the weight of the accessory equipment described would be detrimental. This set up would still be on par with about the best other options I’ve seen though.
