J-Dub can you kindly ask Simon to sell stainless buttons separately? I got my Clear S2+ today. And it has the black button but started to fade and seeing out the metal color under black coating after half day of use. I better like it with the matching silver button.
Thank you!
I’ve made the request and I’ll keep you posted. Some of this first run of the black switches has the issue you described with the black coating being either too thin or not cured properly. Not all but at least some will have this issue unfortunately. The black metal switch should be much improved in the next run which will be used on the desert tan model. If you bought this one from Simon’s store you can send him a message there for your one light if you want a quicker fix but I’m doing what I can to resolve the bigger picture issue. Hopefully all will be well with the next run. Thanks for letting me know.
Thank you for your help. This piece is from banggood but I ordered one from Simon directly for a friend but that one doesn’t arrived yet. We will see how that one keep the black coat. But for me is the best option to buy stainless even if it costs 1-2$ and replace in my light and in the other one too.
Wow, that’s fast…
Do you eat a lot of garlic?
Maybe you can use some solvent or lye or something to remove all of the black coating?
Not really
I will try to remove all the blackness.
Aaaand it’s ruined :person_facepalming:
I managed to take out the black switch but I can’t take out the little plastic ring where the light came out. I putted it in some solvent and it melted the plastic ring but the black paint almost intact. :cry:
So now the button felling out and that means I can not use the whole flashlight.
I really need now a stainless button to replace the mess what I just made. I don’t know now I contact with banggood because of fast erasing black paint or Simon at aliexpress to please send me a replacement part for some money.
I would try Simon.
No need for tears… Simon is having some extra switches made. Just send him a message through the Convoy Aliexpress store here. . He’ll take care of you. Tell him I sent you.
I messaged him about my problem and yesterday I got the reply from him that he has a few and will send me. But I forgot to mention about it here. Simon is the best manufacturer!
Will the clear hosts be offered with the bare stainless switches or only black?
That’s what I like to hear.
It wasn’t just the value of Convoy lights that led me to where I am. It was the very personal customer service from the owner of the company, taken to a level unmatched in my experience that impressed me so much.
Glad it worked out. :+1:
What gap?
Can you be more precise or mark it on picture?
The next round of the clear S2+ is supposed to have the stainless switches. Also, Simon just got a batch of the stainless switches so if anyone wants to try swapping one out they should be listed in the store soon.
He’s referring to a small gap where the tail threads into the tube. Jarder28 contacted me about it.
Look here:
It’s not a big gap but it’s there. I actually checked mine and it too has that tiny gap. I’ve gone months of using without ever noticing that so it’s not heartbreaking IMHO but I will bring it up to Simon so that he can address it in the next run.
I see it now.
I don’t have that on mine.
Did you try to screw switch retaining ring further? It may solve the problem.
I had one grey with gap but switch board was not right in place and retaining ring wasn’t tight and after fixing no more gap.
I tried swapping in from gray s2+ with normal or no gap and still the clear one has that gap. I also tried tightening the retaining ring still didn’t work. It’s not a big issue but its a factor for quality but I think It’s fix-able.
For units with a gap, it could probably be fixed at home by sanding down the body tube a little.
I received my clear S2+ from Shenzhen Convoy. Suprised it came with a blue lit tailcap. I also ordered the new firmware but unfortunately it doesn’t work properly because of the lit tailcap.
When I put a tailcap from my old S2+ on the clear the new firmware has no problem. I contacted Simon to let him know but it is not really a big problem for me.
I prefer just to remove the tailcap light. Do I just unscrew the ring inside the tailcap and then unsolder the LED from the PCB in the tailcap?
Dug in the spare parts bag and found a normal pcb with switch and spring that i ordered from Simon long ago.
Fitted this and it’s all good :+1:
