Yeah I didn’t think of that. As far as I know it’s the 4000mah cells that can handle higher continuous current draw, like 20A and higher. Maybe there’s another new type of 4800mah cell on the market? I would like to see how the first reviews look regarding the current draw.
I asked if it’s a Samsung cell earlier in this thread and did not get a response.
As for current draw, the specifications for cree xhp70.2 say max power is 29W. At 4V, that would mean 7.25A current, plus some heat transfer losses I guess. Or am I not understanding the specs correctly?
That’s just the manufacturer specs. You can push a XHP70.2 much harder. I’ve seen Convoy L6 mods that push 13A through a 6v XHP70.2. The problem we see is that a single cell might not be able to supply enough current to the LED to emit 4200 lumens because it has a boost driver circuit. And you get voltage sag across a battery when drawing current. And when drawing high current to keep the XHP70.2 happy the driver would have to increase the current even more! So let’s hope it’s a decent cell. I’ll rather go for a lower mah rated cell that can supply enough current so that I can have constant current being fed to the LED.
Uum guys, you do know that at 4200 lumens, thé XHP70.2 only consumes 28W of power, right?
Even if we were to count for only 75% total efficiency,including the optics and driver, it would still only require 37W for it to reach 4200 lumens, not 60W.
FYI, I noticed Manker also supplies a 21700 4800mAh cell with some of their lights (U22), but they don’t claim anywhere close to 4200 lm output. Granted, U22 uses a different emitter, so it’s not an apples-to-apples comparison.
I was testing out a similar light just recently, the ODF30, and it was pulling 9A to put out about 3000 - 3100 lumen. Maybe boost drivers, or at least that one, are much less efficient an CC or Buck?
I was looking at Kof3’s 70.2 emitter tests and it’s showing 4200 lumen at 6.2A and 6.25v. That’s a P2 4000K which might have a lower than usual voltage requirement. That’s 39 watts for the bare emitter. I doubt Wuben is using a P2 bin, so I’m erring on the side of caution by saying it needs at least 55-60 watts.
That’s a lot of power for a commercial boost driver. Anyway, this is why I’m skeptical of the 4200 lumen rating. If it actually did about 3,000 lumen then everything would fall in line. We may have to wait and see the actual results. If it can actually do 4200 lumen with that protected cell, I’ll be truly impressed.
Thanks for reminding me about the L30, andrew-amanda has it for $122 delivered, which is even less than banggood. I’m thinking it may fit unprotected 21700 since it fits protected 20700.
L30 is considerably longer but has the tactical tail switch, larger reflector / more throw, but no ramping. I think it could be considered in a somewhat different class than the wuben based on size and UI, the Wuben is not tactical but it’s more compact and has much more versatility in output levels.
L30:
Dual switch/Tactical tail switch but longer size than Wuben
Instant Turbo from OFF
Larger reflector/more throw: (373m vs 222m for the Wuben)
No ramping
Set modes:
1
200
1000
2000
4000
Wuben:
Side switch only, 26.5mm shorter than L30
No shortcut to Turbo (except memory if it has it)
More compact head size but 150m less throw than L30
Has ramping mode
Set modes:
5
130
400
1200
4200
I really like the Acebeam’s Tactical UI and longer throw, for a tactical light / searchlight it’s better.
But this Wuben is a more compact size and with ramping it’s looking good too, better for an all-around light. Something to consider for sure if NW and the price is right.
