Looks like you guys made a winner!
but now
You mean Bugsy isn’t paying me? But, but, but….
I’ve got a normal A6 I made into a triple, I need to get the spacer print out for quote. I’ve been carrying my non group buy A6 with a MTN Fet + 7135 board, a similar TK firmware and triple XPL’s for a couple of weeks now. These are going to be great lights stock, and easy to mod into monsters.
YEEEEESSSSSSSSSSSSSSSSSSS!!!
I never thought I’d see it happen :bigsmile:
EagleEye took their sweet time, but they got it right bang on first go!!!
The UI seems to be absolutely flawless!!! Super low low, hidden strobe, battery check, reverse UI, AMAZING!!!
Thanks so much Bugsy, TK and too dale for da beamshots!
Add me another NW to total 2 NW, 1 CW
Please 1 x NW for me.
Thanks,
uiski
For the record......
I just had an idea.
Wight worked on the driver....
TK developed the UI.....
Dale....well nobody can experiment like he LOL
Kronos opened and reinforced the communications with Neal
This transpired into much more than I thought or imagined because of the people mentioned. Their time and efforts are what made this possible. I am/was just a middle man.
Thank you Very Much to the entire team of Champions that ARE the Champion team including Neal/Banggood and Eagle Eyes....
Hei… you said sample??? Great Job!
Thanks everyone is working hard to get the result.
I suppose after this beamshot the list on the first page will become longer…
add me in for another: +1 CW
Good to hear that the samples are so nice! Well done Bugsy & Co.
So, what is the next step? Any time frame possible now? 0:)
Kind regards
Hi,
Sing me up for 1 CW
Thanks
BR
//Tank
I'm signed up for one BLF Eagle Eye A6.
I would like a total of two, both NW.
Thanks.
and last but not least, the price?
it says "around $22-23"
Sign me up for:
2xCW
Subscribed!
Please tell me the dimensions on the need spacer, so i can figure out. If this is something that i could be try and build myself, maybe by stacking mcpcbs or reflowed copper plates together, or if i need to wait for a GB for the needed spacer, because it is an tricky shape to it.
cajampa, I think it’d be pretty easy to use a couple of extra copper mcpcb’s or a disc if you have those available. A 16mm in the pocket, then stack 20’s on top of that to get the right height…probably 2 without actually measuring it out. Then there’d be more copper under the triple to sponge up the heat.
Realistically, you’re not gonna run a triple very long in this light as it will get hot fast. But the small tube shape makes it very easy to carry and a triple would be a huge flood of light from this host that overall wouldn’t be/isn’t much larger than the cell that powers it. I’ve got one of the Convoy tube lights that ComfyChair modded for Richard and it’s a potent little number to be sure! I like that it slips easily into a camera bag or almost anywhere.
Sounds good & doable thanks Dale.
A triple XP-L will of course get very very hot quick, but that is what modes & off is for
And i think IOS said something about XP-G2 3D being available soon (maybe they already are, i haven’t checked).
Could a triple XP-G2 be a not so hot option? If not 3D i wouldn’t even consider it, but now it is as far as i know the only 3D available.
It is always fun to, i would say almost half of it or more work out a possible upgrade path, before i even get the light.
The XP-G2’s will get hot as well as they’ll be more overdriven. Remember that they’re rated at 1.5A. A good triple with XP-G2’s will easily pull much more than 4.5A, typically 9A or more. So the heat is still there from the overdrive thing.
Drive 3 XP-L at 9A and you’re within specs, making less heat and far more lumens.
(Then again, if you drive 3 XP-L at 15A…)
