I love convoys whole attitude , Simon your great , and the convoy store I return to often to get drivers and leds for other projects , I have a few c8s and s2 , c8 is good for forests and fishing
S2 with 350 tube is so nice , I’m gonna order some more 350 tubes , and a triple in a 350 size is perfect
Keep up the good work
If you’re asking avout XHP35 then 22mm is perfect but this LED can take 4A without issues. And if Biscotti is available it would be dream combo.
As am reading 17mm is available and i’m only waiting for 20mm and 22mm 6000mA with Biscotti.
This is the standard 4 mode 20mm SST40 driver. It actually does it every time entering mode 2. That means stepping through modes 1>flash-2>3>4>1>flash-2 . . . and also from off when mode memory starts it on that level. Annoying for sure but it’s in light I don’t really use much so it’s not killing me for now. Plans for it though were to go into a build for a friend once I’m able to make a custom spacer (lost access to my machine shop).
I have not found a cause or fix. Haven’t tried much though, and doubtful anything short of a re-flash would help
Forget to ask what the input voltage is, if the input voltage is 3-4.2V and the output current is 2.3A 12V, this is already the limit. If you continue to increase the current, the heat generated cannot be sustained by the driver.
The battery bypass is useless in my opinion. The wires fail from a surprisingly low number of battery changes. They seem to fail “safely” with just one end breaking at the solder joint, but it’s a little unsettling having conductive garbage sitting in a battery tube. One of the reasons I like this brand is that the drivers are a little more conservative — can a normal non-bypassed spring not handle 6A without losing temper?
It’s a minor issue — the s12 is the best hiking light I’ve ever had.
I’m not a fan of bypasses either. Beryllium Copper / BlueSwordM’s springs would be a nice upgrade. Not sure how many amps they can handle individually though.
Properly made spring bypasses can be super durable. The solder joints need to be “done right”, and requires coiling the wire. And even despite it could be done relatively fast once skilled, requires testing and overall it's time consuming (imho). This is why I decided to invest on BlueSwordM's springs.
