I have one old XHP70 4500K 90CRI and this is perfect host.
90.2 will go in 4x18. After installing this emitter in all kind of a hosts the only real use is in big heatsinked soda can style torch and Simon just start making awesome components...
I have to admit being lazy and don’t exactly know which type you are referring to, but i do know Wendy from lantedled sells SBT90.2 ’s a lot cheaper.
Correct me if i’m wrong, TA or TomE has ordered some from Wendy, her email adress is stated on lantedled.com
Thanks for looking up some prices and availability oweban! It seems the red version is a bit more expensive than the white one.
Simon, I guess the best and second-best flux bins BR and BQ are worth looking for. I have no idea how far SBT90-R can be overdriven but if it's as robust as SBT90.2 white there's maybe some potential left to achieve more than 2,000 lumens of red light at 15-16A. I wonder if driver-wise the same setting can be used for both white and red. Mateminco sells their MT90 with both LEDs as well as ACEBEAM does with the K30-GT. Maybe someone has already made a pen-test with this LED.
what about the same mode as M21C-U
1.click the button ——> flashlight is turned on with last brightness ——> press the button,brightness ramping up ——> release and press the button again,brightness ramping down
2.flashlight off, press the button ——> moonlight mode 0.01A (0.2%) [This brightness will not be remembered]
3.flashlight on or off, 2-click the button ——> turbo 100%
4.flashlight off,3-click the button ——> strobe
5.flashlight off,4-click the button ——> tactical mode, only 100% ,4-click the button again to quit tactical mode.
6.flashlight off,5-click the button ——> voltage detection (* means “flash” , * pause* means 3.7V, )
7.flashlight off,6-click the button ——> normal ramping mode switch to 4modes 1–10–30–100
8.flashlight off,10-click the button ——> Lock mode,The flashlight will flash once under any operation, which means the flashlight is locked.10-click the button again to quit lock mode,Please note that this is the only way to unlock.
