Also, for a ramping option, have you thought about flashing TKs Crescendo firmware onto your Biscotti drivers to provide ramping on 17mm drivers up to 2.8amps?
I am also working on my CC FET driver again
first prototype board failed, seemed odd but 2 prototypes did not want to cooperate
first Prototype 20mm small LDO and MCU did not work out
new bigger board with SOIC8 MCU and SOT23-5 LDO is now powering up
and its regulating current, fairly low with 250mA ATM but first I need to test out a proper ramping table with Moonlight control over 2 channels
as the OPV is fairly slow with 100nF on its power supply so Gigathrower 2 channel Ramping table does not work out
2. Prototype of 22mm with D1S specifications works
still a few things to be addressed, like The not tented Viases next to the LED- Pad that are ground, they are there to get heat from MOSFET note spread but should be below mask
Simon, do you have CSLNM1.TG gaskets ready yet? I’m almost ready to place an order for some items from your AliExpress store,including the new 5A driver. Thanks
Okay, potentially dumb question because I honestly don’t know the answer - is this specifically for SST40? What’s stopping it being used on other emitters?
Even still, now all we need is 16mm SST40 MCPCB, preferably 5700K
Ask for a C8 reflector with the 7mm bottom hole. It’s easier to center the flat white with the 3535 gasket. Simon is probably still testing the 3030 gaskets.
Will do, appreciate the advice. Problem is that I’ve only got a 16mm flat white at the moment that I put in an S2+ temporarily; should get a 20mm but don’t want to pay 3x the cost of the item in shipping from mtnelectronics
