It’s the same wattage though - the XHP50.2 is a 6V emitter, so it’ll have a boost driver. Unsure how that affects the efficiency, but the S11 also uses a 26650, so longer runtimes.
Oh… ok. I guess my question is how many Amps does it draw from a cell? About 5-6A?
oweban: Pete7874:Description of S11 XHP50.2 states “maximum output 3A” and yet it delivers 2400 lumen? Is this correct??
Yep - should be on the money. 6V @ 3A, 18W…
Testing a Cree XHP50.2 J4 3A ledOh… ok. I guess my question is how many Amps does it draw from a cell? About 5-6A?
My (semi-educated) guess is about that, yep. 18w/4.2v = 4.28, throw in some inefficiency, that’ll be ~5-6.
Pete7874: oweban: Pete7874:Description of S11 XHP50.2 states “maximum output 3A” and yet it delivers 2400 lumen? Is this correct??
How many amps does the S21A draw since it says 6amps on the website?
Most emitters will go above 3V at 6A, but still, a 10A battery will well and truly be sufficient.
Sorry, I’ll start again. Some other data I’ve come across since.
An XHP50.2 at 3A will have a voltage of around 6.2V, giving 18.6W.
An SST40 at 6A will have a voltage of around 3.4V, giving 20.4W.
If you go by a full battery, then 4.2V:
- XHP50.2 is pulling 4.42A (without efficiency drops)
- SST40 is pulling 4.85A (without efficiency drops)
If by a “half empty” battery, then 3.7V (assuming it can maintain full draw, which is more of a buck booster thing):
- XHP50.2 is pulling 5.02A (without efficiency drops)
- SST40 is pulling 5.51A (without efficiency drops).
Again - 10A batteries will do this well and truly.
guys ,who can do me a favor?
i want to know the correct diameter of sofirn soshine LISHEN vapcell 21700
I originally planned to buy these batteries directly in China. What I am depressed is that these Chinese-made batteries are not available in China or very expensive.
Really awkward
Which Vapcell? There are many. HKJ has all that info on his website.
Simon Mao:guys ,who can do me a favor?
i want to know the correct diameter of sofirn soshine LISHEN vapcell 21700Which Vapcell? There are many. HKJ has all that info on his website.
very helpful ,thanks so much
max 21.7mm
i want to know the correct diameter of sofirn…
Sofirn 21700 4000mAh 40A that came in Sofirn C8F (bought on last 11.11): 21.6mm (measured at this time)
Simon Mao:i want to know the correct diameter of sofirn…
ok ,thank you :+1:
Mocarny: Mike C:Double press on a clicky for previous mode? Interesting, I’ve actually never heard of that before.
Personally I can’t see that as being superior to long press for previous mode
With double press you can’t go wrong, double press is always previous mode, single is always next. With this long/short press you can press a bit too long, or too short and have wrong mode. You would love it
I have done some rather extensive testing with double press, but for boost mode, not previous mode. It was brought to my attention in a thread I made asking for these kind of things: Driver giveaway: Constant current 17mm drivers, winners (finally) announced, post #2. (double tap discussion started at post #123).
So I have to disagree a little. I noticed with double press on a clicky that you can go wrong. There is a timing issue that must be dealt with, and that is you have to have a time difference between double press and two single presses. If I want to go up two modes I need to do two single presses. If I do them too fast they are interpreted as a double press. Too me this timing distinction faces the exact same issues as short press vs long press. I implemented it and settled on 200ms time limit for double press.
Believe me, I have tested this stuff a lot. I don’t get short press vs long press wrong. If the time limits are set fine, and you have hardware to support exact timing (like OTSM), messing up short press and long press is as difficult for me as it is for you to mess up double press vs two single presses. With that said, I now have support for double press so I’ll have a look at making a UI that uses it for previous mode. I have the space for it.
Ryzbor:It’s this super-customisable UI: Sterownik driver LED 4,2/2,8A programowalny extended v3.5 HE - www.swiatelka.pl
Also the one Mocarny is talking about. The google chrome translation is very good.Interesting, thanks for posting. I’ll have a closer look at that, might give me some suggestions.
Anyhow, this is a Convoy thread, I should stop hijacking it.
Yeah, do a 23-click to restore the previous configuration. :person_facepalming:
I originally planned to buy these batteries directly in China. What I am depressed is that these Chinese-made batteries are not available in China or very expensive.Really awkward :person_facepalming:
soshine imr21700 4000mAh
w: 21.5mm
h: 71.0mm
On a side note: Sofirn's new SD05 diving flashlight has an inner diameter of 21.9mm, so it might accept even too big cells like Molicel M50A and Lishen LR2170SC.
So what can I say? Just that for me, after week or two I had learned timing perfectly and made no mistakes.
Ps. Double press and all that stuff works much better on tail switch than on side switch
And just to correct, the UI Ryzbor’s posted is not my… “Legendary UI” Thin is it:
http://www.solarforce.eu/proghe.html
Lot easier and less complicated, just what you need, perfectly balanced between complexity and simplicity. And about 23-click…you will never us it, or maybe once, more important is ability to have 2 separated mode groups.
Ok, that’s all
Any one try Lii-40A in 21700 convoy light ,is it fit ?
not suitable
Satan@103TFS:Any one try Lii-40A in 21700 convoy light ,is it fit ?
not suitable
Will it fit in new versions of L21A XHP 35 HI or 3*21700?
not suitable
Simon why don’t you make the body of your 21700 a little bit bigger may be
0.5-0.8 mm. to give us more choices of battery ?
And anyone tried to unwrap the Lii 40A out of this yellow plastic foil? Will it fit then?
Simon Mao: Satan@103TFS:Any one try Lii-40A in 21700 convoy light ,is it fit ?
not suitable
currently not
i have to improve this in the next batch
