Biscotti is for 7135 boards - only 7135's, no FET, so just one output channel. DEL's board is a FET+1 so you need to use firmware that supports FET+1 drivers, meaning two output channels.
You should be able to re-program the MCU once mounted. Couple of causes - clips is not making good contact on the 6 pins it needs: Pin #'s 1,4,5,6,7,8, or couple pins have a short, or a pin is shorted to ground. We had discovered if pin #5 is shorted to ground, can't program it then - those finicky Convoy drivers that had Biscotti on them were like that.
Might want to check for shorts, if you didn't already. some times I find shorts from a good macro picture - easier to see in the pic than by eye, even with using a magnifier. A must is great vision, or good light and magnification (I'm old so I use good light and magnification ).
Dunno bout ethanol, but Isopropyl alcohol is our best friend - use it everywhere, use it by wiping, brushing, etc. Cleans but not caustic to anything pretty much. get the 91% stuff - many drug stores carry it - one 12 or 16 oz. bottle will last years and it's cheap.
Ohhh - must clean the pins with isop. alcohol before clipping. It's a "Must Do" for me - I've had too many issues when I don't. I use a fairly stiff nylon brush, kind that comes with electric shavers for the boards - exc. job in cleaning them up.
For flat open surfaces of boards, wire solder connections, etc., I cut up paper towels in small pieces, then I put the isop. alcohol in a little squeeze bottle, couple of drips on the paper towel, and wipe stuff down. You'll get some paper filaments but if it's getting too much, use the brush. Most of the time I'm using paper towels though - when dirty, throw away - no big deal.
