testing the acrylic paint on an optic…
it goes on a bit gloopy, but shrinks as it dries
unanticipated white face:
you can see some of the uneven coating… not bad for government work
so far so fun
will share bad news if it bursts into flames or melts into a puddle
have only tested turbo for a few seconds … working up my courage…
so far so good… (the material is water based, does not smell volatile).
I hope it gets night soon… lol
The Glow is Strong!
still waiting for dark
painted the reflector on a Thrunite Ti3 w 3000k 219b
update on Lumens output
the triple optic lost 50% of its output from painting the optic
the reflector in the Ti3 did too.
It would be hard for me to recommend the glow paint on optics and reflectors for those reasons…
I see you bought the Ultra vs. the Standard. Performance wise, it seems very comparable, except that once past 60 minutes it’s rated to be nearly double the glow output of the standard.
They also sell a GITD tape that they claim is better than most industry standard stuff. I wonder if it’s much better than the Captank GITD tape I bought.
opinion, I dont think so… imo it is like silicone rubber,
but do your own google… here is one I found
since you asked, I did a test:
I put the probes of my DMM into the powder and there was no change in measured conductivity. On my meter, the display says 1 when the probes are apart, and the display goes to 0 when I touch the probes to each other.
I did the same with the wet acrylic paint (it is water based). It showed increased resistance, that is, the number went up to 1.8, not increased conductivity (number below 1)… (Im not well versed in meter use, maybe others can explain)
What an incredibly interesting topic! I ordered all the parts for a triple 219b (purple) S2+ yesterday. I found some gaskets but found them quite expensive for what they are so ordered some gitd tape and some gitd vinyl sheet. Can’t wait to try it out!
Might try that paint as well on the pcb
