DQG Tiny 4th 18650 xml-2 review
oh
well there it is!
:slight_smile:
mis remembered
i guess you could make a short tube but i have never heard of one for sale
wle
Right, I was just wondering if maybe a shorty tube from some other light would workā€¦
The Nichia 319 mod was for better Tint/CRI, better UI, and higher efficiency,
not for higher output.
The XML2 in the stock light gets very hot while the body of the light remains fairly cool.
If you modify it with a proper PCB and heat transfer for the LED, you will quickly realise that it can only dissipate approx 10W heat maximum
(which is what an XML2 or XPL or Nichia 319 etc will generate at 3A).
Any more power than that and you are just going to burn your hand faster.
Tailstanding indoors with no airflow, mine gets hot and thermal throttles on high after a minute or so.
If you want a nice compact EDC light with good runtime and decent output for most common tasks, modify this light if you want, but keep the max level under ~10W.
If you want any more light than that for any extended period of time, get another, larger light with more surface area to dissipate heat.
Was the switch improved on new ones ?
what do you mean by ā€˜new onesā€™?
i had one from dec 2016 that i complained bitterly about, due to the terrible switch, design, and or manufacturing that made it come loose
wle
I see a gear best deal today . Do you think the ones being shipped today have improved ? Will epoxy help ?
epoxy might help make it stronger against the pushing, not sure if it would have thermal implications, or if it would permanently fix it.
i would guess the current ones, still calling themselves ā€œIVā€, are the same.
theoretically you could write to the head of the company and ask, but i never had much luck with that.
if there are new versions, he may not know what gearbest is selling currently.
wle
also i donā€™t see any deal - they have been as low as $13.99 recently
I did not know that . Iā€™ll wait for better deal . Thanks .
2.8V in my test.
WOOOT?? Any deal around? Iā€™ve seen thereā€™s a code for 26 USD at m4dm4xā€™sā€¦ do deals at 20 usd or under happened recently?
Also, the 4th version itā€™s been produced for a long time, any news about maybe a new version in the air?
exactly the information that I was looking for in this threadā€¦ with the new 18350 cells around, such this light screams for a short tube of some kindā€¦
no luck I guess? :frowning:
I wonder how can I improve performance of my Tiny.
I like the beam profile, wouldnā€™t want to make it much floodier. Or much throwier either.
Turning it to a triple (f.w. triple Oslon Black) is far beyond my skills.
Swap LED?
The LED included is quite good, I donā€™t see any stock emitter that would be 3V, significantly more efficient and not floodier.
Dedomed Samsung LH351D might be an improvement, but a small one and I feel itā€™s not worth the effortā€¦.
Res-modding?
Iā€™m not sure even minor current increase is a good idea without improving thermal path.
But maybeā€¦ā€¦should enable more improvement than LED swapā€¦
Improving thermal path?
Dunno, maybe potting with Arctic Alumina and attaching a copper plate on top of the light engine would enable me to spread some heat outwards?ā€¦
Painting interior with white heater paint?
There is GITD strap inside and it clearly glows. Which is an evidence that thereā€™s stray light hitting flashlight walls. Painting white would put some of this light in the spillā€¦Has anyone painted the interior of a TIR light with white paint and reported the result?
The only thing I would like to do is swap the LED to LH351D 90 CRI. But it is quite hard to do because it sits directly on the driver pcb.
You just talked yourself into not modding it. It is really perfect for what it is. Plenty of light. Plenty small. Easy UI. Just plain works. It doesnā€™t even get that hot, sure it gets warm but not D4 type hot. It is one of my favorite all around lights. If it ainā€™t broke, donā€™t break it. LOL
Would that:
http://kaidomain.com/S026103-19mm-x-17mm-x-1mm-Glow-in-the-dark-Water-tight-O-Ring-Seals-Green-5pcs
o-rings fit the Tiny?
Iā€™d like to make it glow a bit brighterā€¦
While potting the Tiny 4th light engine, I let some glue escape to the switch area.
The switch got partially gluedā€¦.
The glue was silicone based and I managed to somewhat clean it out. The light turns on, but the switch got much harder to press and lost the click feeling.
Iā€™d like to try to replace the switchā€¦but for that I need a replacement.
Does anyone know the replacement or can tell what should I check to find something suitable?
that is going to be hard - both to find and to replaceā€¦
even then, i think the design is poor - it is likely to break off like 2 of mine did
wle
There seems to be a trend towards a low mid mode. 80 lumens is ridiculously low for a mid mode. A mid mode needs to have a good amount of light with and a good balance of run time. Ideally between 150 - 220 lumens.
what i would want in a UI would be 7 or 8 steps, evenly but logarithmically spaced, with a really fast single-click switching
like the astrolux S1
steps would be like 1-3-10-30-100-300-1000
and a way (long click) go to the previous level
the S1 comes close but its steps are not spaced like i would like
the DQG tiny IV just has 3 somewhat useful levels and a turbo
the low isn;t low enough, the step to M is too big
then H and turbo are too close
ack
wle
