I’d really like a pair of the PB-9, the ones with the twin pulleys.
A hundred foot of paracord and a 4:1 mechanical advantage. Don’t know what I’d use it for but I feel I need it. :exmark:
I do know I couldn’t afford them, the paracord isn’t a problem.
Something else I didn’t realise I needed until you posted. :bigsmile:
Not the orange and black ones, they might scare the little kittens away before I get my furry key ring.
The EDC gear Caribiner arrived today and it is built along the heavy is stronger line of thought. Just a couple of areas of concern, the weak spots are on the hook part of the carabiner and the spring gate. The hook would be better if it was more rounded instead of V shaped because they thought that another wrench size would be a good idea, the valley of the V looks like a stress crack waiting to happen. The gate spring it also crudely made of by pressing the piece out of flat materiel and leaving it as square section and roughly finished.
The carabiner has been given a good buffing on the two flat faces and a quick buffing round the edges with no attempt to clean anywhere afterwards.
All of this I feel is totally acceptable on a carabiner costing about £4.60 delivered. It’s a big lump of stainless steel. :bigsmile:
I wouldn’t want to risk my life on it but I’m still tempted to get another and see what I can use the 4X mechanical advantage for with a length of 550 paracord. H)
Definitely the pocket hanger was better finished.
The carabiner just needs introducing to some Solvol Autosol, a couple of cotton buds and a soft cloth. It’s just gote some of the polishing compound in some of the harder to get at places.
As I said at this price it’s a nice slab of Stainless Steel with useful shapes.
I’ll post here when mine arrive, they look like they are strong and the dimensions, 7.2 in x 3.7 in x 0.39 in and the weight 2.47 oz combined with the shape with the ridges pressed in should make for a strong pair of scissors - it all depends on how well the handles are attached I suppose.
Who says I’ll buy anything that is bright and shiny?
Couldn’t resist these shiny colourful things.
“Detachable 6mm diameter Multi Color Screw” Dimensions: 3.90 in x 0.43 in x 0.43 in (9.9 cm x 1.1 cm x 1.1 cm)
Hmm, detachable 6mm screw, 99mmx11mmx11mm I’m thinking lanyard beads and washers, maybe 18 for £2.50.
The EMT Shears have arrived and they are pretty much full size scissors with a two fingers one thumb grip.
I thought that they were horribly scratchy at first but then realised that one edge of the scissors has tiny serrations on it.
The grips are well attached and show no signs of looseness. The blade sections have a “safety” tip, no sharp points which could increase any injury that you were dealing with.
Quality, they aren’t up to Fiskars quality but for £3.50 they’re O.K. Much better for one drop of Sentry Tuff-Glide on the pivot.
They deal with “Blue Line” dressing fine and will cross cut 550 Paracord as well as angle cut for melting the end into a point.
Talking of Paracord the Pretty Shineys arrived as well -
Twelve beads harvested to go into the 550 Paracord bits box for £2.34.
Had to buy one of these as well while I was checking prices.
I’m sure it will clutter up my EDC bag come in very handy.
Thanks for the heads up, Steve. So in your opinion those shears are worth putting into a first aid kit?
The multi-wrench looks cool but I’d worry that the steel might be too soft for anything but a one-time emergency use. I’m interested to know if it would stand up to regular EDC use working with nuts and bolts.
Yes, they would do the job, they don’t feel as solid as some scissors and the pivot is a rivet type but looks able to be hammer tightened down the line if it gets loose, plenty strong enough for EMT use and maybe even those kitten tails.
The multi wrench won’t be put to hard use, if at all, it looks like the metal is too thin but you never know.
