It sounds like you know your stuff. I would totally watch any YT video you uploaded on electroplating.
Yeah, I have to learn stuff the hard way.
Nobody in the industry is willing to share anything, so I have to use my chemistry knowledge, backwards means of searching for product compositions, and the like.
It does make for a fun learning experience.
And while it is actually more expensive initially to make the products and purchasing the necessary materials,
if I actually manage to reverse engineer an inexpensive process, I will be able to plate almost all aluminium lights with copper or nickel.
The problem with ordering plating supplies online is the shipping, and I don’t want to pay exorbitant amounts for a local shop to do it, for a flashlight anyway.
Here are the steps I have to do, and what backwards means I’ve had to actually make it.
1. Prepare a sodium hydroxide aluminium anodization strip solution.
I’ve had to go to a soap making shop to get sodium hydroxide and some plastic containers to contain the solution
2. Prepare a sodium zincate solution for electroless(no electricity) plating the aluminium.
I either have to purchase zinc oxide and then dissolve it, or put zinc sheets in muriatic acid, then neutralize it with sodium hydroxide to get zinc hydroxide, which will then allow me to dissolve it in another NaOH bath.
3. Prepare an alkaline copper solution for plating.
Easy. Just get some sodium carbonate and dissolve the copper electrochemically.
Will not really work though, because of copper carbonate’s tendency of being insoluble.
I have to find another way to dissolve it.
I’m specifically trying to make this:
A flash copper solution is a alkaline solution containing a copper salt dissolved in the solution.
And yes, I’ve already seen it multiple times. That’s the only solution I haven’t been able to reverse engineer/make from scratch yet.
At over 90$CA per litre, it’s not cheap though, at all. That’s why I’m trying to make my own.
You may be able to find some help at chemistry stack exchange.
Thanks a lot for the help anyway, as I’ve spoken to a lot of people about this, which includes Nurdrage, NileRed, a chemist friend of mine working at an electroplating shop, and someone on BLF has helped me, but I will not discuss of their name.
It’s a proprietary solution, and it’s hard to do, but it is perfectly possible.
Normal methods of doing this only produce insoluble copper oxide which then needs to be processed using patented dangerous chemicals and temperatures.
However, if you introduce electricity in the process, you can basically force dissolution of copper inside of the solution in the form of…
sodium cuprate.
Proprietary solutions of flash copper are made of sodium cuprate.
If everything works out, I should have a blue solution today(which I do), and a blue no precipate solution tomorrow!
So, some very good news.
I managed to make some sodium cuprate, which is flash copper!
If I can manage to make the zincate solution, I should be able to try and plate copper onto aluminium.
Congrats on your progress
Since zinc is needed under copper
Im wondering what percent of people would choose just zinc plating, and what proportion of people would prefer copper
Some dont like copper, im one who does. So i would vote for copper.
Maybe at some point, a poll?
Zincate wouldn’t work too well here, since electroless zincate plating makes for a very thin coating. But if people want an electroplated zinc coating, it would work well.
Something like:
- Deanodized
- Copper
- Nickel
- Zinc
- Silver(+ min qty needed)
- Gold salts(+ min qty needed)
I’ll post my progress in a few minutes to show you what I’ve made.
I won’t make any progress this week though because of exams.
Guys, I don’t think I’m going to be able to do anything related to copper plating on aluminium.
Making zincate is easy, but getting a copper solution that will actually stick to aluminium is a nightmare.
This will be postponed indefinitely.
Aluminum oxidizes almost instantly in air. That’s why welding it is so darn hard. Just to test, submerge some aluminum and sand it with sand paper. Leave it in the solution, and fire up the rig. Hopefully the sanded area will plate. If this works, then you can always brainstorm on a chemical de-oxidizer method for the next go round.
no worries, I think Gold would be nice
yeah, some say Im a Dreamer… LOL
I haven’t plated gold, but I don’t think it’s scary expensive at all. So little is needed it’s fairly reasonable per light.
I Googled for some evidence to back it up. Found this post:
A. Hi, gold plating is cheap. It is incredibly thin. Greatest property of gold is ability to be spread/plated as thin as 30 atoms.
1 micron is 10,000 atoms thick.
That’s 333 times thicker than needed.
Problem is gold platers know people are ignorant.
We pay as low as $.06 per part for gold plating. We gold plate everything we can.
@Joshk and jon_slider, I have no problem getting the zinc to stick.
It’s the copper that I can’t wrap my head around. I know what materials I need, but I do not have access to them.
Aluminium is probably the holy grail of plating metals.
If I can manage to do this, then anything else is much easier.
What do you need?
Pyrophosphate mainly.
I can easily dissolve any copper into solution using a galvanic cell process at high concentrations(8-10g/L), but I specifically need Pyrophosphate as a weak base for the zinc to be etched away, but the copper to stick.
Sodium cuprate(copper dissolved in sodium hydroxide) does etch the zinc, and plates copper, but sodium hydroxide attacks the aluminium, meaning you get a gap between the aluminium and copper, and copper does not stick.
If I get can get Pyrophosphate, then I’ll easily be set for making copper plated lights.
If you have access to pyrophosphate, I’m willing to pay a nice buck to get it shipped here.
I’d need about 1-2kgs.
I don’t have any. All I can do is drop an email to a guy on youtube that knows his chemistry. I sent a short email to Cody at Cody’s Lab to see if the topic pique’s his interest. If so maybe he can join the conversation about making some, or do a project on his channel in the future about the topic.
Yeah, thanks a lot, but I don’t think Cody is going to be interested by this.
Anyway, I’ve dropped emails to suppliers in Canada and some on Alibaba to see if I can get small quantities of pyrophosphate(1-3kgs) for a small batch for electroplating.
