The Q8 is one of the easiest Anduril flashes you can do, next to the D4S. I recommend looking it up and getting the <$10 worth of AliExpress parts to do the job. Super rewarding.
I got my TK style D18 last night. I was worried that it wouldn’t be floody enough to replace my M43 but the beam pattern is pretty similar. The amount of light this thing puts out is impressive.
Recieved my D18vn today, I can barely get it to work I have to screw the head on so tight! I’m using button top HG2’s. Iv’e also tried button top 30q’s with the same problem.
Also looks like it has a spring bypass… don’t know if that is factory? if its not so you think its keeping the springs from compressing enough?
Have you talked to vinh? He normally does that to support the higher power demands that a spring simply cannot do. He’s done this to a few of my vn lights.
I was able to spend a couple minutes and check things out. Looks like too much solder on springs and they cannot compress. Bummer. Emailing him now. Hopefully we figure something out.
I just realize one of the batteries was a Sofirn 2200mah and not the VTC5D. I remeasured using 3x VTC5D and got 12,400 lumens at 1s. Better but still less than what I expected.
Lumens at 1s are Ahh! and all, but are not really relevant and no one uses that measurement. I think we’d all like to see something more realistic once the output settles a bit. Maybe 15 to 30 seconds or maybe Turn on and 20 seconds so we see how it drops.
Firelight, even the Blue springs benefit from spring bypass. I chopped a D Maglite and used the Q8 reflector with it’s board and XP-L HI emitters, counting on just the springs the output seemed low, a single tail spring bypass gained 500 lumens, I removed the one on the driver and used a solid copper contact. Now the light can make the expected 5000+ lumens on a hot cell.
