i wonder if doing spring bypass is worth it or not since the load is basically shared among 3 batteries so each batteries are only lightly loaded and this light also regulated so the only thing effected by the spring bypass would be a longer regulated ouput.
Mine is the new style MT01 ( with the metal switch) and definitely can’t fit any protected cells. I noticed the Neutral white XHP50.2 has a yellow/green hue around the hotspot in the one i have. (the common tint-shift syndrome that Cree LEDs seem to have in shallower reflectors. I see a MTG2 swap coming for mine.
Ok, another question… Have anyone else seen a weird dimming when the MT01 is on High mode? On my light when turned on high, after 2 or 3 seconds it begins to dim, and continue to dim really quickly and turn off for a split second, than fade back on but into medium mode. when i hit the button it goes back to high mode and does the same thing again.
Can't speak for MT01, but I don't experience that on my MT02 and SC02. I did a quick test on my MT02 (3x18650 similar to MT01). Data shows 30s runtime for first 4 brightness level and 1min for Turbo mode.
Have you try swapping with another set of batteries (button top)?
I bought the Haikelite MT01 CREE XHP50 V2 last week and tracking shows it will be here tomorrow. I really don’t care for neutral or warm color flashlight and usually buy only cool white lights but this looked like a good deal for less than $40 bucks so I got one. It comes in one flavor of 5000K so we will see how it goes. I may end up de-doming a XHP 50 6500- 7000K led and modding it. Would like to find a SMO reflector as well. Can you tell I’m a Flashaholic? Order hasn’t arrived yet and I’m already modding the thing. Ha! It’s hard for me to get around having only one leg, but when I’m used to using the recently acquired prosthetic leg I’ll go get some beam shots for this and my new Klarus XT12GT that came a few days ago. I love the Klarus, it is a monster thrower with a sweet beam and awesome hotspot. :+1:
i noticed that on my MT02, it dims and then up again but to lower mode and double click is able to go to turbo again but i noticed this happens on almost empty cells so could be a warning that the cells need to be charged?
The cells werw at 4.12 volts, but its likely voltage sag under high current loads with laptop pulls. I will add button tops to my 25Rs to see how they work.
