ENEDED
What I can tell so far this is the closest thing to a D1S with 26650, knurling and Stainless bezel, (everything I wish for on the D1S) so I’m totally down with it. I probably won’t use the ramping that much anyway, but at least it has it.
Only thing holding me back now is waiting for the Green color version to surface.
More Pics:
That’s the quick and dirty of it for tonight, it got late on me.
As far as the ramping goes it is slow. It does blink slightly at max.
With the slow ramping perhaps its saving grace is the instant access to lowest from off. Single click.
Instant access to turbo from off. Double click.
More as time allows, I’ll toss a video up of the UI when I get a chance.
Can you measure reflectors width and height please?
No problem. I’ll get some measurements up sometime this weekend as time allows.
EDIT ADDED MEASUREMENTS OF REFLECTOR FOR Cula
The diameter of the reflector at head end at widest part is: 46mm
The diameter at the base of reflector before it steps down to the centering area is: 25mm
The overall length of the reflector from top to bottom is 41mm* If you remove the centering spacer take away another 1mm from that making it 40mm
Hope that helps, if more measurements are needed let me know and I can get them when I can.
Without LiitoKala 50A is no go for me.
Thank you :beer:
What cells have you tried? Any fitment issues? Can you measure the tube ID?
That would be unfortunate, but cells can vary slightly as can tubes, let’s see what D_Pierre says. I wouldn’t have a problem doing a slight reaming of the tube if necessary. My LK Lii-50A meausre 26.7mm at their widest point.
Battery Tube Measurements:
Thanks for this, and the photo!
Looks like plenty of meat on that tube for a bit of reaming, probably only need about 0.3mm for the LK 50’s
Green version is now listed!!
“Under restocking. It will be available soon”
THANKS Freeme! …. I assume you made this happen! :+1:
Hopefully the code won’t be expired and will be valid for the green version too.
Hey Freeme
can you ask them to make the ramping faster (about 3 seconds from low to high and turbo/moon access). Will get 2 green if they meet my request. :smiley:
That green one sure looks great. Love the shape and size of this flashlight.
Got me thinking on how to mod this one….
I would replace the driver for sure but also want to keep charging possibility. Is there a way to keep this driver only as a charging board and piggyback another driver on top? Which components should I remove (those which power the Led) and which to leave (to keep the charger function)?
Those are cheap OEM case for flashlight.
Spent sometime with the light. Ramping time will take you 1s-1.5s to reach "High" (~70%) from lowest (visa- versa). However, if you ramp up to Turbo, it will take you rough 6s to ramp down.
I doubt it will happen.
Besides ramping and the shortcuts from OFF, is there a group with regular modes, such as L-M-H ?
Also I don't understand from this (quote in the OP) exactly what is "mode 2" ?
And the "4x clicks/mode 2" mystery continues...
Turbo Momentary? What does this mean exactly?
I think the “Turbo Momentary” is like the “Tactical” setting on the Q4 where the light remains on as long as you hold the button down. Press the button and it’s on turbo. Release it and it’s off. I guess you can signal that way.
Not sure about the other stuff.
Thanks, that makes sense, so in that mode you’d have nothing but the Turbo momentary.
And that’s what Freeme meant by “then you hold press to keep light on,when you release will light off”
I don’t have a Q8 so I didn’t know abput that mode, but it all makes sense now, thanks!
Still wondering about if there’s a L-M-H group, or is it just ramping only.
Nope, ramping mode only with shortcut to turbo using double click.
Starts on moonlight with single click while on ramping group.
I’m working on a video to demo it for clarification.
Can anyone confirm what cells work and what don’t? Need to know what to invest in before I pull the trigger.
Compatible 26650 battery models:
Yes No
Keeppower 5200mAh Protected
Littokala 5000mAh (blue)
Littokala 5000mAh (black)
Rofis 5500mAh
IMALENT 5000mAh MRB-266P45
Will a protected KeepPower work?
