d_t_a, thanks for that detailed info! Glad I ordered them then. I really don't use the long press so will give it a try in my clear C8 and see how it goes.
Any idea how long before the blue led will drain a battery?
I got a Convoy C8 stainless steel bezel, but it seems it fits perfectly only for the Convoy C8 Clear/Silver, but it didn’t fit the Convoy C8+ Oak Brown (won’t screw in completely, with a big gap), does anyone have this issue?
Code for sand colored C8+, thanks Freeme. The new style C8 is starting to grow on me.
Hi freeme,
Any chance I could get a coupon for the Convoy L2 please.
I sent a PM and posted in this thread about a week ago but not heard back.
The lighted tail switch works fine on my C8+. All Biscotti functions work fine, even long press to moonlight. However, when I installed it, it defaulted back to mode 1. Reprogrammed and all is well on mode two with memory turned on.
That is sexy, shame it doesnt come with a lighted tailcap from the start, i would gladly payed a few more bucks if it had that.
no i dont have skills for that stuff, sadly i would just break more then good, like i said i would pay if it came from the start. im not JasonWW or those that can build a flashlight with their one hand…
Was the ss bezel not fitting a one off problem or had anyone else found it doesn’t fit?
Hope that Convoy did not made changes to the threads. Mine fits fine but i only one copy from earlier batch.
I’ve lost the code for the c8. Dohhh.
Any chance it can be sent again?
Thanks Freeme.
Where did you get that lighted tailswitch from?
I ordered several pieces from Gearbest, and tested most of them with Convoy S2+ old firmware and also S2+ with Biscotti.
Obviously all work when used with the “old firmware”, but when I tried the lighted tailswitch (Gearbest describes as Convoy Omten 1288 lighted tailswitch blue LED), a few simply won’t work properly — it’s stuck in one mode, half-pressing does not do anything.
But a few of them works partly on Biscotti:
- half-press will advance to the next mode
- but a long-press does not revert to Moon mode
so far, I have yet to test a lighted tailswitch which recognizes the long-press (I did also test on Astrolux C8 which has BLF A6 UI, and it shows the same behavior, short half-press works, but long half-press doesn’t — it’s recognized as a short half-press; which means, I couldn’t get to the special modes which require a long half-press from Moon mode)
Interested, thank you very much.
