The NW tint is nice. It’s not as nice as my high cri Zebralight, but it makes the outdoor colors pleasant (especially at 1/5 the price).
It’s got an orange peel reflector which smooths out the hot spot. I’m still thinking of putting on some sort of diffuser film over the glass to create an even more uniform beam.
I’ll check soon about how far the beam extends. I like my floody Zebralight especially because I can see where I’m stepping without moving my head. A quick glance down with my eyes can spot roots or rocks. I can’t recall if that’s the case with the Eagle Eye.
It’s light in 18350 form and stays put on the inexpensive strap I got form Banggood. The strap simply goes around my head and doesn’t have a top strap, but still works well.
The 430 lumens at the top might not excite most people but it has worked well for use in my dimly lit shop where it lights up the bandsaw blade or drill bit placement well. It’s not like having 1000+ lumens reflecting harshly back into your face as it glances off a machine or shiny surface.
For outdoors, I haven’t gone camping with it, but unless you’re trying to spot critters 50+ yards away, you should find it good for hiking and hanging out around the campsite. I think the 25 lumen low setting is a bit too high for reading at night. I like less lumens at night and especially camping where I can read without illuminating the entire tent and possibly waking my wife or son. It’s fine, but a lower setting would have been nice.
The magnet isn’t all that powerful (as stated before) and I kinda wish it was. I could use it for more things in the shop if it had a more secure hold to my machines.
Overall, it’s a really nice light for under $20. Not sure about waterproofness with the usb and the not-so-tight rubber cover. I’m not going to try a dunk in the sink. Still, I’m glad that I got a couple.
They will be glued in place when i have the driver sorted out and everything reassembled.
I use Kafuter UV curing “glass glue” for the TIR, and probably universal glue for the boot.
At the moment the TIR is held in place by a galvanized spring steel wire ring (it’s the bottom coil cut off some spring i had lying around)
To add to my impressions above, the spill doesn’t quite reach my feet when I’m looking forward. The angle isn’t wide enough. Still, I don’t believe that it would prove to be much of a detriment when hiking trails. Whenever I hike in the East (mainly the Adirondack Mountains) I find myself staring at my feet because of all the rocks and roots, and that’s in broad daylight!
I just checked and the nitecore hc30 tube fits perfectly. The Ee shorty tube fits the hc30 but I can’t verify if it works out of the box since my hc30 is without a driver as of the moment. Photo with my shorty h03
Pretty much where I got the idea. I bought the A6/S1 shorty tube from AE and 2 thin o-rings I had lying around (can’t remember where I got them from). Fits perfectly out of the box.
The hc30 tube on the X1r slims it down substantially making it easier to attach to the armytek headband.
Got mine…took a while.
I like the illuminated green switch.
Brightness is ok.
Wish it came with a clip as I will not be using as a headlamp.
Magnetic base (as reported by others) is not nearly strong enough to hold light at 90 degree angle on any metal surface… just slides off, they should have tested this and added a stonger magnet for the extra few pennies. Kind of disappointing if you wanted this to be handy for working on stuff and having your hands free.
I had some down time, so I swapped out the led to a 351d 4000k 90cri and the reflector to a TIR. I swapped out the green led to an orange led, which isn’t as bright… But does anyone know how to mod switch light so that it’s constant on and turns off when you turn the light on?
There is no easy way to do that. That led is controlled by the charging circuit mcu and you would need to reprogram the UI. That’s not gonna happen.
If you want to leave the red led alone for battery indicator purposes, you could sever the pcb trace going to the orange/green led and run a constant power wire to it. It would be on all the time, including with the main light on. You would have to break battery power to turn it off.
That’s the closest I can see to doing what your asking.
Thanks for the response, I was thinking about swapping out the driver to one of Lexel’s drivers but I think the driver is fine the way it is. Too bad there’s no easy fix to the switch light issue.
Just got mine, the NW is indeed really nice i also like the beam pattern better on this light compared to my Nitecore HC33 (XHP35)
The thread is dry and rough though.
