[1]Tiny silicon particles could power lithium ion batteries with 10 times more capacity
University of Alberta chemists have taken a critical step toward creating a new generation of silicon-based lithium ion batteries with 10 times the charge capacity of current cells.
“We wanted to test how different sizes of silicon nanoparticles could affect fracturing inside these batteries,” said [2]Jillian Buriak, a U of A chemist and [3]Canada Research Chair in Nanomaterials for Energy.
Silicon shows promise for building much higher-capacity batteries because it’s abundant and can absorb much more lithium than the graphite used in current lithium ion batteries. The problem is that silicon is prone to fracturing and breaking after numerous charge-and-discharge cycles, because it expands and contracts as it absorbs and releases lithium ions.
The researchers examined silicon nanoparticles of four different sizes, evenly dispersed within highly conductive graphene aerogels, made of carbon with nanoscopic pores, to compensate for silicon’s low conductivity. They found that the smallest particles—just three billionths of a metre in diameter—showed the best long-term stability after many charging and discharging cycles.
[…] “As the particles get smaller, we found they are better able to manage the strain that occurs as the silicon ‘breathes’ upon alloying and dealloying with lithium, upon cycling,” explained Buriak.
[…] The study, “[4]Size and Surface Effects of Silicon Nanocrystals in Graphene Aerogel Composite Anodes for Lithium Ion Batteries,” was published in Chemistry of Materials.
John Payton
to
Callahan’s Crosstime Saloon
3 hrs ·
I hope this doesn’t start a flame war…
A journalist asked Tim Cook why iPhones are so expensive
“Well”, said Tim Cook, “that’s because the iPhone replaces a whole bunch of devices. A phone, a camera, a watch, a music player, a video player, a PDA, a voice recorder, a GPS navigator, a flashlight, a calculator, a portable gaming console, and many other things. Surely, a high price is worth paying to replace so many devices!”
“Then why are Androids so much cheaper?”, asked the journalist.
“Because,” said Tim Cook, “an Android replaces just one device. The iPhone.”
Breakthroughs are less likely to happen given the consolidation of so many industries and the failure of citizens worldwide to keep track of who owns what and for what reason. The cream doesn’t always rise to the top if there’s (much) more to be made making certain that long term investments run their course.
If the emitter were lying flat on the ground, light shining perpendicular to the emitter would go straight up. Isn’t this how LED emitters tend to work already? I don’t see how this new tech would change that.
Nothing else published since 2014. I wonder how well it’s progressing. I still haven’t made the move to 4K TV… and it seems that with the resolution game pretty much won, now it’s about accuracy of color rendition and customized motion management, thinness, as well as increased efficiency. Imagine a 60’ diagonal LED TV that rolls up for easy stowage (like into a ceiling fixture) and consumes only 5w of power.
Solid substrate lithium batteries are also getting close. More efficient, longer lifespan, smaller form factor, and far less volatile.
