Most analyzing chargers only do capacity discharge at 0.5A to 1.0A. Are there any not-too-expensive ones that does 3-5A testing?
I ordered this and it seems to do its job ok so far, i am very happy with it:
Ok so basicly i need to make some thermal protection. There are 2 choices i have. 1 is connect all 4 ground pins to the same thermal fuse thingy, but i need you to tell me whether this will somehow hinder the charger. The other choices are: 1) use 1 fuse for each of the ground pins and basicly cut power to the pin which overheats or 2) basicly use some ceramic plate and put it over all 4 batteries and if it overheats (meaning 1 or more batteries overheated) cut the power to the litokala 500 completely.
I could really use this information. If i connect all 4 ground pins on litokala together, is that ok or will i somehow hinder the charging/discharging process ?
Anyone ?
