It’s not a big deal though. Would prefer the original way, but as long as you configure it right, it’s going to matter at all.
High CRI with a very nice balanced floody beam(SST-20 of course).
Superb handling.
Stronk magnet.
FD2 SST-20s. I got lucky since the first units came with FD2 SST-20s.
Great Anduril UI.
Creamy output
Good thermal handling.
Stupid good waterproofing.
PL47-2 AUX off: 0.09mA (6.3years to drain it’s 5000mAh cell)
PL47-2 AUX on: 1.75mA (119days/0.33year to drain it’s 5000mAh cell)
The AUX leds are BRIGHT, but also sucks a lots of juice. As a comparison; the light consumes 3mA on the ramp floor (219b leds).
But i use the AUX leds to indicate the light is “active/not locked out”. I always unscrew the tailcap to lockout my e-switch lights. So the high AUX drain is no biggie
So I just received mine and put a 30Q in it. I got the sst20 4000k version. Is the 30Q a bit too high current for this version? I have not noticed any issues but can’t see any specific warnings about using high current cells.
Should be fine. 30Q peaks at 20A, settles at about 15A, thats max 5A pr. emitter. The SST-20’s can handle currents above 6A, so no worrys
The driver will throttle down due to heat, waaay before the emitters takes any damage
Can anyone measure the inside diameter of the Fireflies PL47 gen II tube? What 21700 batteries are you using? I bought 2 Shockli IMR Purple 4550mah, and they are somewhat thicker than normal, 21.5mm or so. Will they serve for the PL47 GEN 2?
Yep, having the same problem with my 26650 Shockli batteries, they want come out my Haikelite SC04…
I don’t have a gen II, but my gen I measures 22.2mm(I assume gen II has still the same batterie tube)
i already recieve now.
confuse a ramping mode .when i press 1 click. its high level. but i press to level down and press to off.
when i click again. its jump to high level again. not remember last level.
What am I supposed to do?
