Thanks FmC.
Ok so here you go: BLF-A6 single channel battcheck vpt
This should work, but might be good idea if someone with actual programming knowledge could look at it. I think it makes a hell of a driver out of a cheap 105C, without major modifications (just add OTC).
This was was tested and calibrated in an Eagle Eyes X6 host, spring to switch tailcap bypass, 8xAMC7135 105C driver from Simon Mao, spring bypassed.
OTC was Murata 1ĀµF,0805,16V, X7R, soldered a bit strange
The .hex file can be found here
Anybody want to do a bit of work for me? I promise I canāt pay anywhere near a fair wage for your time, but I could send a few bucks via Paypal.
DEL previously helped modify blf-A6 so that Pin 3 could control the FET on my TripleDown boards. It didnāt look to me that it was a major change to the existing FW, but what do I know?
Job 1: Do the same thing with STAR momentary: make a ā255ā value toggle pin3 instead of the normal output
Job 2: Do the same thing with STAR dual-switch, as well as add dual-pwm support (that might be a bigger job?)
I think your knowledge of coding and all the driver stuff exceeds mine by farā¦
I wonāt even bother to mess with job 2 ATMā¦
Anyways, I did this out of interest and for the purpose of learning something, maybe. I would be surprised if it works and if Iāve done it right. I have no e-switch host to test it.
But maybe itās a starting point for someone who knows what heās doing:
diffcheck job1
EDIT:
I am sorry for posting such crap. This doesnāt even compile right. I had
#define TURBO 245
in there, and at least it compiled. Must have taken it out before posting. But anyways, it doesnāt work, Iāve tested it, goes 245 on channel 1 instead of driving the FETā¦
I recommend github.com for sharing code. That way if you need to make a change you always have the version history to go back to.
In hopes itāll help me actually get stuff done, I posted my todo list at the beginning of the thread:
Help and encouragement are welcome.
The repository is currently using bzr + Launchpad instead of git + Github, but migration is still possible if a majority of the people involved want to switch.
I realize git won the DVCS wars, so bzr is definitely not the most popular choice. Launchpad now supports git though, so itās also possible to use git without actually moving to Github.
As for Launchpad vs Github, many of their features overlap but Github is organized per-person while Launchpad is organized per-project, Github has some wiki-like features, Launchpad has much more extensive bug/task tracking, and there are a variety of other significant differences.
In any case, the options are on the table but would need a majority in favor. So far, there has been very little interest in revision control and project management tools, so Iād be happy with pretty much any system as long as people used it. Iād much rather review merge proposals instead of pulling files from forum posts, pastebins, and dropboxesā¦
Iām an avid github user. All my personal code is on it and all my code for work is on it as well. Iām biased, but when I found the Launchpad site it took me too long to find the source code. To me thatās the number one feature of a code repository - SHOW ME THE CODE. With Github a project might be under a user, but thereās no limit to the number of contributors you can have. Also itās distributed so anyone who wants to do their own thing can fork off of the main repo and it doesnāt affect that main repo in any way. Maybe the code gets merged back in, maybe it never does. Github also has organizations (that are free to create) for projects that turn into a real community effort. A lot of projects that start out under one personās account get transferred to an organization as they take off.
Thatās just my opinion but I havenāt actually contributed any code yet so I consider it fully without merit or standing. Iāve got a lot of ideas though, and debuggers recently delivered and a sack of Nanjg 105cās on a slow boat from China headed my way. Iām fully cognizant that thereās nothing you canāt do on Github, Launchpad, Gitlab, etc and I will get source code from wherever the developer chooses to share it. When I have something to share Iām putting it on Github.
From what I recall of its early days, Github started as a simple place for individual people to share git repositories. Other features were added later but werenāt as deep a part of the overall design. So, it excels at āshow me the codeā. Launchpad was designed more as a full-featured large-scale project management platform and a replacement for older systems like Sourceforge. Designed specifically for facilitating Linux distro development with thousands of contributors and complex relations between individual component projects built together into a whole. Its broader focus makes the code somewhat less front-and-center.
Both are good tools, though their styles are very different.
Git and bzr are functionally and conceptually almost identical. The main differences are a matter of interface. However, there is one significant conceptual difference ā bzr has a concept of a āmainlineā but git does not. This explains some of the consequences of that: Merging in bzr: The git approach vs the bzr approach
In common usage, git is dramatically more popular. They use different terms for the same concepts, which can be confusing. Git puts all the heads or tips into one directory while bzr defaults to one directory per head and one head per ābranchā. Git prefers to wrap or reimplement common tools for use on a single directory while bzr encourages using stock tools on separate directories. Bzr supports git as just another pluggable storage back end. Git favors fast-forwards and implicit merges, while bzr favors explicit merges.
For BLF purposes, the technical differences are mostly unimportant. Itās primarily a matter of what the participants want to use.
Soo, the attiny25/45/85 has a useful extra feature (not available in tiny13) that Iāve been meaning to bring up. Tiny25/45/85s can measure their 1.1v bandgap reference. And this is really useful to us because by setting the ADC reference to vcc and measuring the 1.1 bandgap we can calculate the battery voltage. Of course itās backwards from how measurements are normally done (use a known reference to measure an unknown) but it doesnāt matter.
Looks like setting REFS[2:0] to 0bX00 will select vcc as ADC reference, and setting MUX[3:0] to 0b1100 will select the 1.1v internal bandgap as the voltage to measure.
Apologies for letting time slip by, not bringing it up sooner.
I would have posted this in the attiny25/45/85 thread but it seems to be occupied with other things at the moment.
Hmm, interesting. So if I understand correctly, we could free up a pin and maybe remove two resistors on 1-cell tiny25/45/85 drivers? And this wouldnāt work on zener-style drivers because VCC is artificially capped?
In exchange for freeing up a pin and potentially removing a couple components, the voltage resolution would be decreased somewhatā¦ but weāre already getting ~4.5 ADC units per 0.1V, so we have some resolution to spare right now. And itās currently only using 8 of the 10 available bits of precision anyway.
Is this more or less correct?
Yep. I think the greatest benefit might just be gaining a bit more room on the 17mm single sided pcb. Since it sounds like we need to add components to get better stability. Small decoupling cap, FET gate resistor and/or pulldown.
Any takers? PM me. Iām offering $10 for Job 1 and $15 for Job 2 if they work. I think there should be a fair amount of crossover between the two.
Iāll do it freely if youāre not in a hurry (I have a busy week ahead) and are willing to accept that you might flash a few buggy revisions. I just got my AVR programmer working and itāll be a change from trying to hack something from scratch, which Iām certain will involve spectacular failure at some point
Part 1 seems pretty clear but about part 2, do you mean dual-pwm as in the STAR momentary, with ALT_MODES driving pin 5? Does that mean you also need PWM mode selection? Iāll post back in your driver thread once I get around to getting something done.
Iām happy to help as much as I can testing revisions, I just need someoneās help that understands this better than I do.
Both should have pwm options for pins 5 + 6 (like star momentary already does) plus toggle pin 3 for turbo and such. Really exactly what DEL did to blf-a6 for me, but versions for momentary and dual-switch lights
Dual-pwm was really overdue for STAR dual-switch anyways, but JohnnyC just didnāt see the demand for it I think
Fyi, Halo asked me if I was disabling the AtoD upon sleep mode in my Narsil version, and noticed I wasn't (same as STAR Momentary). So I added turning OFF the AtoD during power sleep mode and it cuts parasitic drain in half -- big gain for a small easy mod in the e-switch firmware we commonly use.
So, the STAR Momentary and Ferrero-Rocher both do not have this disabling of AtoD from what I can see, unless there's something I'm missing. Post #789 here has the sleep_mode code. Post #790 here has the result of using 10X values for the R1 and R3 - reduces parasitic drain by a factor of 10. I think this resistor mod needs more testing and review, because it sounds technically it's out-of-spec of the Atmel MCU's, and I'm not sure it can be used with 13A's.
I think this resistor mod needs more testing and review, because it sounds technically itās out-of-spec of the Atmel MCUās, and Iām not sure it can be used with 13Aās.
Itās not a hard spec like the allowed VCC or frequency range (and even these can be stretched). What I could find in the 13Aās doc is:
The ADC is optimized for analog signals with an output impedance of approximately 10 kĪ© or less. If such a source is used, the sampling time will be negligible. If a source with higher impedance is used, the sampling time will depend on how long time the source needs to charge the S/H capacitor, with can vary widely. The user is recommended to only use low impedant sources with slowly varying signals, since this minimizes the required charge transfer to the S/H capacitor.
The way I read this is that you can use larger resistors but the ADC will not run as quickly, which we donāt care about at all.
Ahh, that's interesting... So sounds like a pretty good solution for us. If reducing parasitic drain is important to you, then for our e-switch based lights with our custom firmware, this option of using 220K and 47K resistors is the way to go, combined with modding the code to turn off AtoD during sleep mode.
In my tests, I measured from 0.314 mA originally, then with the mods down to 0.016 mA, about a 95% drop.
I am also not sure how much the MCU reading the ADC will affect things when you are using resistors that are that high of value.
I haven't tested values this high myself on the drivers so this is just a guess, but I am predicting much lower precision overall if you go to 10x higher values.
Also, remember that higher values affect MCU turnoff times when you cut the power. This won't matter much for momentary only, but for any clicky setup it is something to keep in mind. It may not be an issue, and you may be able to compensate for it in other ways, but it is something to keep in mind.
All I did was simple tests of a cell at 3.6v and one at 4.1v and my firmware blinked out the correct voltage. Need to do a lot more testing, but I've never done calibration to begin with. I've found accuracy though to be pretty good, within 0.1v for the most part using the tables TK had, think from Dale's measurements.
Edit:
Did more tests of various cells, various levels:
Voltage Level Blinking |
Actual Voltage (DMM) |
18650 cell |
4-1 |
4.12v |
AWT 2500 |
3-5 |
3.505v |
HE4 |
2-8 |
2.811v |
Sam 15M |
4-2 |
4.21v |
30Q |
4-2 |
4.18v |
MJ1 |
4-1 |
4.14v |
MJ1 |
2-8 |
2.776v |
15M |
2-7 |
2.725v |
15M |
2-7 |
2.691v |
15M |
It's about as good as any of my other e-switch lights.
