Yes, nothing altered function-wise. The transistor was flipped to the opposite side of the board because of space issues, and I used .063" copper between the main board and contact board to keep them in alignment when installed. Onboard antenna was snipped off also because of no space for it. Bluetooth worked after the antenna mods, I even loaded a new profile and it all worked wonderfully. I even tested the connection range afterwards out to about 12 feet and it worked fine, it may have worked farther than that but I didn't try it. I even re-tested all those same things after the pill was put together for the final time but before it was dropped into the tube and it worked.
I even deleted all the pictures of the build it made me so mad. Wish I could delete it from my brain too...
