They cut faster and truer, meaning flater, I can get closer to edges and radiuos’s. Use them wet or clean when loaded up, less wear, they last for along time depending on hardness of the stone.
Here are a few MCPCB’s that were done on a flat surface and sand paper, then I hit them on a fine flat stone. Not enough to make a big difference when using AS5 or any other thermal goop, but when 2 surfaces a really flat, you use alot less, almost none. Better heat ransfer…. debatable … It can’t hurt.
The bottom MCPCB was screwed down at those shiny spots, the surface it was bolted down to, couldn’t have been that flat. Would it make a big difference using thermal paste?
Well the de-domed SST-40 in Turbo heats up steadily from the get go, what I would normally expect since it is being driven at 9amps on a Basin 26650.
. The Sliced and Diced 3v 50.2 Heats up very fast, the stock driver and spring set-up will only drive the 3v 50,2 to almost 13amps, something like 12.85amps is what I seen using a Liitokala Black and Gold.
. I have not run any of the out of the box stock lights till they got warm or hot, just turned them on to see if they worked.
tm07 used a dedomed LED and it went from 235kcd (969M) to 367kcd (1211M).
From what I’ve heard the spill becomes warmer and the hotspot colour doesn’t change a lot. Tint isn’t too green aswell.
357kcd at 5M mine is a de-domed 7500k SST-40 it’s does have some green/blue tint or hue in the spot with a bit of yellow in the halo when you compare it to the NW on a White wall. Just don’t compare them side by side.
