If still available, i’d be interested in the triple XHP 70.2.
Thanks
Hi , I remember you …
Ordered a black XHP70.2 NW.
Thanks Freeme! :+1:
Thank you for your continued support!
Interested in the XHP70.2 x 3 version.
My MT09R XHP70.2 is on the way… However, reading part of this thread i get the impression some units may have issues like under performing due to wrong FET or else…
How will i know whether i have a ‘good’ one?
It’s not really a wrong FET.
It’s just a part that has slightly higher internal resistance and lower rated current(40A vs 50A+ of the FET used in the original TA driver).
Other than that, it isn’t problematic.
I get that, but doesn’t it impact performance - like under 20k lumen on turbo?
Maybe i’m just confused about what i read in this thread… I got the impression someone had a lower then expected output because of it.
Still, is there a way to tell which one i will get - possibly without taking the driver out…
Sorry if this is a non issue… I’m just a bit anxious you know… :person_facepalming:
You will get about 18k lumens stock.
You will not be able to get 20k+lumens without a spring bypass.
Mine gets 19k lumens with Texas Ace’s own driver without a spring bypass
Basically, the lumen rating of the lights are overrated by quite a bit.
24k lumens is the startup lumens Texas Ace got on one of his samples with P2 binned XHP70.2s, bypassed springs, and his own driver.
That is the absolute best scenario, and yet, Haikelite put on this number as stock.
Mine is on the way too. 25K is definitely far fetch but I will be happy to settle for 18K for this size. For over 20K, you probably need at least 4*XHP70.2 i guess.
That was my estimate too with only 3xXHP70.2… but i somehow got carried away by enthusiastic comments about this light and the new TA driver, thinking it would really go over 20K.
I already have a Lexel modded MF-01 that puts out 13K+ of beautiful Nichia high CRI NW, so the stock MT09R wont be a very noticeable improvement. As you say, this light is probably too small to handle such output.
I won’t complain either if i do get 18K.
The stock driver should be fine as long as you don’t bypass the battery springs.
If you do bypass them, the increased current can fry the FET. It’s a cheap and easy to replace part if you can solder. So no big worry.
Interested
It’s depend how you measure the lumen…
I measured 17050 lumen for the mt09r TA version… mf01 xpl version got 10720 lumen…
Thanks Freeme! :+1:
Got it today… 30Qs in the charger…
I got my XPH70.2 NW version a while back. This has become my big go to light. But with the easily accessible moonlight mode and defeatable blue switch light, this also makes an excellent bedside light. Everyone on here should have one likewise with the Q8.
I’m thinking about getting one. I’m still waiting just to make sure they get all the bugs worked out.
It is a very nice light indeed.
Has anyone done a lux measurement on his MT09R? I’d like to have some comparison numbers. Measured 113k with my neutral white on a UNI-T (which I think measures too low with neutral lights)
Mine with wire spring bypasses and new fet does 21500 lumens and 108600 cd.
Your is perfectly fine. 3 smallish reflectors with big leds it is more a flooder than a thrower.
