Does BOD mean brown out detection?
the ability to stay on through super short power cycle?
If so I think this would be a good thing.
Is it a good thing?
Is it a good thing?
Yeah the Emisar is watt I was comparing it to.
However there IS a nice subtle design aspect of the FW3A body I do like A LOT which stands out. The sleekly well-crafted ācombat gripā ridge right above the tail cap. Extremely useful and a feature I wish many of my rear switched single-cell flashes had incorporated.
Elegant simplicity.
I may buy this just for this brilliant point alone and the way it was executed.
Kudos to the brain that insisted it being there.
:+1:
PS. I wanna clarify that this finger grip ridge isnāt uncommon per se. Just that it appears the FW3Aās is actually large enough for even glove wearers butt yet isnāt too large as to be ugly and out of proportion to the rest of the outer design. Plus it looks well smooth machined and thus comfortable. Sharp ridges and fingers pressing down donāt work for me. :sunglasses:
Yes.
It is like LVP, but built deep into the attiny85ās innards. Basically, if voltage drops below 1.8V at any time, even for a few microseconds, itāll stop code execution completely. The main purpose of this is to make sure the MCU wonāt attempt to do anything when itās out of its supported voltage range, because its behavior is unpredictable when voltage is too low. This helps prevent random eeprom corruption and things like that.
The benefits outlined in the attiny manual donāt seem to matter for flashlight purposes, but it doesnāt hurt. Iām using BOD for its side effect ā increasing standby power. Because it makes no difference to battery life but it makes a lot of difference when attempting to exit momentary mode. Without BOD, it could sort of get stuck in momentary mode because there was no fast way to force residual power to drain.
Without BOD, standby power was so low I had to use a high-end 6-digit Fluke meter to measure it. So, basically zero. Or ~0.0001 mA, if I recall correctly. This is impressive, but too low for this purpose. So with BOD, standby power is about 0.02 mA. Low enough to be negligible for battery life, but high enough to make the light shut down only a second or two after power is removed.
Put me down for one!
Please add me to the list for one!
Put me down for one please!!
I would be interested in for sure. Thanks!
@Toykeeper
I redid the AndĆŗril UI graphic a bit and sent it to the BLf adress on Toykeeper dot net
Any comments if good or useless?
Hi there, cool looking project!
Put me in for one.
2 more please!
Late to the party but iāll have 2 (one of each LED config).
Thanks!
interested from one LH351D
Can the rest of us see it?
Agreed. As for the factory reset thing, knowing a little bit about some issues, youād either have to have a complete duplicate set of incorruptible memory to re-programme the thing, and worry about bootloaders (also corruptible), or checksum it on startup and clear out anything looking wrong and start again if possible, or just declare it dead, return to manufacturer. Difficult to see how to do any of these hypothetical things.
Unless the worry is just about getting stuck in a loop due to a bug, configured into non-volatile memory with no way out. Which is quite another matter.
Or just trying to start again quickly with whatās still there, in a default configuration. Which makes sense.
Turning on BOD is the right thing to do at this point, despite resistance from some other people. It has been a controversial issue in the past, but I think the benefits are more accepted nowadays.
I redid the AndĆŗril UI graphic a bit ā¦ Any comments if good or useless?
Yes, it should make things easier for printing in black and white.
I need to do some updates too, but Iāve been procrastinating about it because thereās not much room left to add anything. It could use some info about how to control aux LEDs, for lights which have those, but Iām not looking forward to rearranging things to make it fit.
Iām so looking forwards to this. Am I on the list already? If not, Iād love to buy at least one with the LH351D LEDs.
Nice to see this project coming together!
When do you think it will go into production TK? 3 months? 6 months?
Is there any idea of how long after the first run the LH351D run will happen?
This looks like your first post on this thread.
