Looks good! I finally got round to playing with Anduril last night and figured most of it out from looking at the diagram and reading anduril.txt. I got stuck in muggle mode for a while because I thought I was in momentary mode but thatās definitely user error :person_facepalming: . The only things I wouldāve added are brief explanations and default/min/max values, which youāve done! :+1:
Thank you! Do you mind if I translate it into German? I'm not sure if joechina is already up to creating something comparable (printable pdf in a nice layout).
Therein lies the problem though Jason, she DID state default was set at 1/150, so any REASONABLY intelligent individual would see that the term default showed 1 out of a possible 150 steps, so how do you idiot proof for all the different idiots? I know my own idiocy can, many times, be quite different from the normalā¦ just saying. Once you start configuring the light it becomes pretty evident.
And with this adjustability it becomes easy to set the momentary in lockout to whatever level suits your fancy. It is also easy to set the stepped mode for however many levels one wants, one or three or whatever. So it can suit the needs of a lot of different appetites.
Stepped mode canāt be configured for one mode. See here but you could probably set the ramp min and max values to the same level and effectively have a 1 mode light.
As to optical sensingā¦.
Oveready Boss / Lux-RC use this feature to accomplish more than programming.
When the light accidentally activates, itās usually in a confined space (i.e. pocket) and that space reflects a lot of light back towards the head. They sense this light and act upon this knowledge ( I donāt remember how, but I remember they do it wrong ).
Anyway, itās the best solution to the problems with accidental activation that Iāve seen.
Nowā¦.would it be possible to port it to FW3A?
I donāt think so, you canāt drive a LED and make it sense at the same time. It works on Lux-RC because they have an auxiliary LED that they use as a sensor.
But we have more and more lights which feature aux LEDs as wellā¦
Can we just stick with programming pins + USB for the foreseeable future? We arenāt going to make a Lux-RC clone with $0 budget at a random Chinese factory
OTOH, Iāve heard itās difficult to configure the sensitivity in a way which doesnāt get false positives or false negatives. Iāve heard the reflection sensor has a tendency to either fail to detect reflections from dark surfaces, which are the most likely to start firesā¦ or a tendency to trigger itself when it shouldnāt. Itās neat, but due to the light-absorbing and heat-absorbing properties of black matte materials, the types of surfaces it really needs to respond to are exactly the ones it has difficulty with.
Iām not sure the default values really fit in a generic manual though, since they are different for each model of flashlight. A lot of options really depend on which light itās being used on. So I mostly tried to write it in a way which can be copy/pasted into the middle of a printed user manual with only minimal need for editing.
I am in for 1 please! Reading back through I didnt see my name on the list. My wife is gonna throw me out of the house soon, also waiting on a Convoy L6 and an Emisar D1sā¦ā¦. Really debating the D1s since I keep hoping Hank will do a 26650 or 27700 version like with the D4sā¦.
