I would personally prefer to be able to use the clip on a cap, or remove it, so I hope it is not glued. If it is glued, I will use it with the clip as is, and be fine with it.
So mostly iron with a bit of nickel. If I remember correctly, these are likely to represent the core of large planetary bodies - the space material which has undergone differentiation (light stuff floats to top, heavy sinks to bottom leading to compositional stratification). Not too disimilar to earth - iron-nickle core and āscummyā crust floats ontop.
Wiki link to the meteorite this material came from:
Sure got quiet I thought I might get either a āthatās a stupid idea because ā¦ā¦ā or āthats a neat ideaā or some response in between ā¦ā¦ā¦ I donāt know what to thinkā¦ā¦ maybe I AM missing something.
Hereās some on-topic noise. I just read the review of the recent prototype, which notes that the battery tube is not quite long enough to accommodate button-top cells.
Isnāt this a glaring oversight for a product that has been in development for so long, with several prototype stages already past? How difficult can it be to add 50 thousandths of an inch, so that another entire family of common cells can also be used?
I will be pretty disappointed to find this thing in production and still unable to accommodate the collection of high-drain cells I have accumulated for my D4, D1S, and Q8. I donāt want to have to maintain another special set of batteries for this one application.
Proto2 worked fine with button-top unprotected cells. However, proto4 only fits flat-top unprotected cells. I think this is caused by the known issue with the driver being in the wrong spot, and it should be fixed by correcting the driver fit.
Itās supposed to fit like thisā¦ which is how both proto1 and proto2 were made:
ā¦ but proto4ās driver cavity wasnāt made quite big enough, so it ended up more like this:
I hope itās clear from the diagram why this could cause issues with battery length. Restoring that part to how it was in earlier prototypes should fix it.
Welcome to the world of lithium batteries where there are no standards when it comes to the physical size.
Unprotected flat top cells are recommended because button top may or may not fit. This was known information for many many months. In post #1 it says the maximum battery length is 66mm. If you have several button top cells then there is a chance some will fit and some wonāt.
Unprotected flat tops, on the other hand, will all fit which is why they are recommended.
At first I thought you were talking about Bluzies review where a flat top battery did not fit, but that review was 3 weeks ago and was talked about here already.
I donāt normally even buy button top cells. It is much easier to make a cell longer than it is to make it shorter. It would be nice if it fit both for the sake of those who donāt want to go monkeying around with their flat tops or, invested heavily in button tops.
The battery tube length is locked in. Itās a very narrow range of lengths due to the double tube design and both tubes have to have good contact for good functionality.
Itās quite possible Neal will offer the light with the option of a good flat top cell. I have zero concerns about the battery length.
Which āreviewā are you referring to?? Please provide a link. That information is not correct. The length of the battery tube was not the issue.
_
Nope, not a āglaring oversightā at all. See above & see TKās detailed explanation quoted below outlining the suspected real problem.
_
Hopefully you will not have to deal with disappointment. Hopefully your particular accumulation collection of high drain cells will work just fine.
But, even in a worse case scenario (which seems extremely unlikely); the FW3A just holds one cell. So, in the very, very, very unlikely event of āworse case scenarioā; hopefully you will be able to deal with the disappointment, get one or two cell that fit, & be at least moderately happy with the cool new FW3A. :+1:
Thanks for the illustration of where the real problem lies. I had not seen that diagram, and probably never would, due to the time required to read through 7400 posts. Just for the record, Iām not lazy - I did read every post in the D4 review before buying, and also every post (to date) in the D4S thread, though I havenāt bought that one yet.
The issue seems to be simply a matter of paying more attention to the size tolerance of the various parts, which hopefully the manufacturer will address before beginning production. But yes, it would still bother the heck out of me to see so much good work go into this project and then have the versatility crippled by poor manufacturing.
Are you still not sure if I am serious or kidding? Since you didnt respond to my post explaining the cap clip, I was not sure if you just didnt understand what I was trying to do or maybe there was something wrong with the design that would keep it from workingā¦ā¦ā¦ maybe it is a good design but without explanation your reply suggests otherwise.
