Really like the fact that three of the (many more then just 3 of course) nicest BLFers I know have coded for and worked on the D4.
But they also added to the FW3A among many more so even here the FW3A wins
Still having a hard time not to order one
I think the beauty of creating such a small light is in its practicality. Chasing peak lumens while sacrificing a good tint and beam consistency (XPG3 vs 219C) seems to detract from its true potential. Additionally, the thermal management capabilities of this design are severely handicapped. To be honest, and in my opinion, I'd like to see a true high efficiency constant current driver installed, such as the LD4. Once again, given the true strength and uniqueness of this design, I can't see any reason to go beyond 9A. Even with 90CRI 219C's that'd be over 2000 lumens OTF at that current. And you might actually be able to use the Turbo for more than 5 seconds. But I'm just afraid we all worry about spec sheet numbers way too much. In a shelf queen hot rod that's great. But this is a light I have serious hopes for replacing my SC63w as my EDC. Exceptional tint and comparable efficiency are needed for that to happen. I use 40-400 lumen modes about 10x as much as turbo in my EDC's, so performance here is where it counts.
One other thing that has been talked and thought about here is how this light differentiates from another BLF fan favorite, the Emisar D4. I'd like to suggest the merits I mentioned above would help with the overlap between these two wonderful lights. Again being honest, the D4 is better suited to high amps and max lumens when you consider it being a quad and having notably more mass and surface area.
Yes, we certainly have the Nichia in mind, unfortunately not for this upcoming light. But you act like the beam as well as the tint of an XP-G3 is unacceptable. Itās not. Itās a good beam as well as a good tint. It comes down to deciding on whether you prefer the few more lumens of XP-G3s or the little better beam and tint of the Nichias. It has nothing to do with practicality or big sacrifices but subjective preferences and both choices are valid. For this upcoming light we chose the XP-G3 and far fetched arguments will not change that. So if XP-G3s make the light unusable for you Iām sorry, but I also canāt help it for now. The same applies for (hopefully) a later version, if the Nichias make it for someone unusable I also canāt help it.
Another option is to mod the light, which wonāt be very difficult.
Ah yeah theyāre both very small , you are right D4 looks bigger olon the pics, must be the bulge for the switch. Funny, D4 has side switch and larger max OD, FW3A tail switch so a little longer.
Itās the diameter that makes the bigger difference here. The FW3A is slimmer than the D4 and doesnāt have any bulges. Even the Astrolux S41, which isnāt as bulgy as the D4 is noticeably more bulky to me in the pocket than otherwise-similar lights with straight tubes.
Iām glad to hear there may be a 219C option in the future. I may be an extremist here, but the longer Iām into lights, the less patience I have for low CRI. It takes a lot of lumens to make a significant visual difference, but even a modest difference in CRI is a stark contrast outdoors. I can solder, so Iāll buy these no matter what emitter they come with, but a lot of people canāt. Also, due to this lightās amazing price point, buying new emitters adds about a third to the cost.
Jared, like you I donāt run my lights at maxā lumens all the time either (I suspect very few if any here do), but itās nice to have the light blast when I want mega light. I guess I donāt understand the concern. If one wants a long runtime and a cooler light we just run it there as you and I already do. Itās like an automobile, my car can go I donāt know how fast because Iāve never driven it that fast, but just because it can go really fast that doesnāt mean I use it at that speed.
Or like alcoholā¦ just because I buy a bottle and have a drink now and then, it doesnāt mean that I drink the entire contents.
Iām trying to understand the complaint, but I simply canāt. Iām not trying to be difficult.
I think the complaint is that both direct and linear drivers (the FW3A driver can operate in either mode, depending on output level) are inefficient on anything but max output. A FET always runs the LED at the maximum current the battery can provide, where itās well under its peak efficiency. A linear driver burns off the difference between the batteryās voltage and the LEDās forward voltage by turning it into heat, which is an obvious waste. With low-forward-voltage LEDs like the XP-G3 and the latest Nichias, thereās a considerable amount of waste when the battery is fully charged.
A switch-mode driver (buck, boost or buck/boost) can be more efficient, as it can provide exactly the desired current for the selected brightness and transform any extra voltage into current, reducing the load on the battery in the case of a buck driver. These also cost a lot more to produce and take up a lot more space. To get the sort of current possible with a FET driver requires especially large and expensive components. The highest output mass-produced 1x18650 lights with switch-mode drivers (Nitecore TM03, Olight H2R) are barely scraping the low-end of the outputs hobbyists have been getting with FET triples for years.
Thereās been some of the same discussion with the Emisar D4. To gain the efficiency requested, it would have to be larger and more expensive with a lower peak output. Thereās merit to that (a Wizard Pro with Nichia 144A swap is one of my most used lights), but it would be a completely different light than the designers set out to create.
Yeah the extra space needed for buck/boost and added cost make it hard to use in our BLF specials
Now that the triple channel gives more stable output lower modes it just is logical to use it in a small light like the FW3A
Zebralight manages to get boost drivers into lights this size, but they run at 3A max instead of ~12, have only one emitter and cost $80, not $30. Kaidomain actually did manage to make a cheap boost driver light with pretty high output in a C8 body, but most people donāt find a C8 comfortable to carry in a pocket (and I havenāt seen independent verification of its 2600lm claimed output).
