Can you check if your retaining ring in the tailcap is centered and that the inner command tube fits inside of it? You can also try to put the command tube in first and then screw on the outer tube.
I tried it without the oring and it still wonāt wotk. Thanks for all the help anyways
I donāt have a retaining ring on mine. I had the one without it. Itās aligned really well as far as I can tell.
The tail cap and head works fine on the 18650 tube so Iām sure the short tube is the issue
I tried to check continuity without the battery tube. There really is no beep. I think the inner tube really is just defective. Tapping at both ends of the inner tube doesnāt seem to beep either.
I wiped everything with IPA and yes theyāre all bare metal.
Ok. I got frustrated and mad which was a good thing I guess and put it on a vice. It works for now but I still get some clicks that do nothing. Better than nothing I guess. Thanks for all the help! Hopefully I didnāt make it permanently an 18350.
Edit: It doesnāt work again . After fixing it I laid it on my table. Wanted to play around with it so I picked it up and it doesnāt work anymore.
Unfortunately I canāt take pictures until end of the next week. I actually remember having to tighten the whole light quite a lot to ensure it register every click.
Ill try to measure my 18350 inner tube as well.
Checked the switch on my defective FW3T. This is the one with the unreliable switch.
The switch is super-simple. Literally just a piece of spring steel on top of a PCB. The steel is held on with kapton tape. I removed the tape and cleaned underneath with deoxit. Then replaced the tape with fresh tape.
Now the switch works, but the light still does not when I use the black inner tube that came with it. For some reason the tube just isnāt long enough. Tubes from other FW3 lights work just fine, but the one that came with it is just too short to make contact.
To fix, I think Iād need to pull out the driver and/or tailcap and add a bit of extra solder along the contact ring for the inner tube.
IMO, the FW3A is a nice light (though I donāt use mine), but the manufacturing tolerances are too tight for inexpensive production. I know it was designed to be something unique, but a more simple design, perhaps with a side switch or a mechanical tail switch, would have resulted in less issues.
The FW3A is kind of like a cheap HDS light. I know the HDS is way over-priced, but perhaps the FW3A is a bit under-priced.
I had one of my FW3A powder coated. sort ofā¦
I guess the first one went bad, after a couple triesā¦ the guy replaced the light and powder coated the body and tail capā¦.
He assembled it and sent it back.looks kinda cool.but it Doesnt work
I am still trying to figure out where it all goes southā¦The light engine may be faulty.I can , by swapping things around, and omitting the clip, get the light to work in a basic fashion.
it turns on, ramps about half wayā¦will not go turbo with a double click. Will not show battery with triple clickā¦
itās all wonky. a failed experiment I am afraid.
The inner black tube, I have two now, and they are markedly differentā¦.no idea if the paint is screwing up continuity or what
I cant screw the brass retaining ring into the painted tailcap, overspray?
It lights with both tail caps, with no clipā¦ but no turbo or other multi button commandsā¦ odd
