Basically it sounds as though they are having a lens built to exactly match the Carclo. Like Neal said, some will be sent to various people to test before they are used in production. If they preform as good as the Carclo, great.
If they donāt, at least it is a fairly simple swap to a Carclo.
Iām āthinkingā behind glass they will probably end up preforming about the same as the Carclo behind glass.
Is there any estimate of when the colored lights will be available? I must get a purple TK Special for my wife. Will the colored lights be available through Nealās Gadgets like the current versions?
So if Iām reading this correctly, those who have ordered the FW3C donāt need to do anything because Neal isnāt shipping those out until the 10511s arrive. Is this everyone elseās understanding?
Hi Neal ā thanks for making this possible! Is the āblueā option actually āice blueā? Because I donāt see any other blue option on the order page and the regular blue has a rather weak glow power (only 15), while ice blue is much more decent (60). Tritium Power Chart.
I like the idea of a very wide spot anyway, so I will be swapping the optic in the flashlight. That said, Iām not an expert modder, so unscrewing the bezel in a dust free environment is about the extent of my expertise.
A certain supplier of Carclo optics has the option on the 10508 optic for āCarclo XP-L Mod (not necesary for XPL-HI or Nichia 219) +$1.50ā Anyone know if this will be necessary for SST-20 emitters?
If you have a glass lens and a TIR behind it, you have the ācorrect opticā.
The biggest issue with the optic they decided to substitute for the Carlco was that it was a one piece solution. It didnāt come with the glass lens, and you couldnāt just swap it out for a proper Carlco unless you had that glass lens (or a suitable replacement).
I only care because I may want to swap it out eventually, and I dislike proprietary parts/software/etc where there is no measurable benefit to using them (for me anyway).
EDIT:
I realize now that you are probably talking about a light that is as yet not delivered (so you canāt just check yourself) and wondering if you are going to receive the Carlco/glass comboā¦ I can only speak for myself because I donāt know when the cutoff happened, but I received the glass/Carlco combo on my order (NW XPL) and I was a way down the list for getting the code.
