Just hold onto your nubbin.
Silicone comes unstuck to easily. Goop much more tenacious bond and remains flexible. Maybe this whole thing is a non issue if the switch is never taken apart. Has anyoneās come un-nubbined otherwise?
If the switch isnāt disassembled I donāt think there is room for that to happen?
It would be nice to know the materials being used so one could use an appropriate adhesive.
If mine gives me issues I might try Bisonās Plastic Adhesive since itās what I have.
But I donāt have high hopes for it working since Iāve a suspicion that the big part might be PP which the Bison isnāt suitable for.
In case someone wonders, that Bison adhesive is just a mix of PVC and solvents so it sort of āmeltsā the parts together.
Unfortunately I donāt have a very good soldering station so canāt really test the softening or melting point of the plastic accurately.
Yepā¦ :+1:
If you donāt happen to have any Silicon laying around, you can use one of the below if you happen to have them:
3Mā¢ Weatherstrip Adhesive
It even comes in 3 decorator colorsā¦ Clear, Black, & Yellow ā¦ā¦ to expand your choices.
And if you want your nubbin to never ever come loose, use a dab of this:
3M 5200
Bottom lineā¦ just about anything will work.
BUTā¦. whatever you use, clean the old glue completely off both the nubbin & the rubber switch cover. This is important if you want the new glue to bond correctly.
Aquarium silicone is about as good as youāll get for any mastic type stuff.
there is no need to disassemble the tailcap...
if a repair will be necessary on day its good to know upfront to look at a small part not to disappear.
otherwise :leave it as it is and stay happy ;)
Best advice so farā¦ā¦
You don't have to tell me twice!
common sense prevails once againā¦.
I just removed the clip because I plan to holster it ( of course, bezel side up while doing it), and aside from the usual black o-ring, there also was a thin, white o-ring placed in front of the clip (facing to the head) presumably to prevent the clip from rattling.
What do you guys think, put back the white o-ring back when the clip is off?
Today in FW3A news: Big feels for little nubs.
That O-ring is there to keep the clip from rotating when the tailcap is tightened. If you donāt use the clip, it may be a good idea to take the white O-ring off tooā¦ and replace it with a thicker one to fill the gap. It doesnāt matter for waterproofing, but putting something in that gap gives it a better tactile feel.
I had a lose Driver retainer ring on my flaschlight. I could hear it wgile opening for inserting the battery.
I experienced the same issue with the driver not sitting against the keyed section properly. It's fixed for now, but it took some effort for two reasons:
- The retaining ring has loads of slop in relation to the threads, and can come extremely close to the inner contact ring.
- No one bothered to blow my sample out after machining, and there were tiny aluminum chips trying to short circuit whatever components they could.
Hopefully it's fixed now and I didn't miss any stray chips that are waiting to cause more trouble.
I hope this is the right place to ask. I have never modded a flashlight in my life, nor ever used a solder. But I couldnāt wait any longer and ordered one in XP-L HI 3D. I hope to replace the LEDs with LH351D 4000ks. How difficult will it be to do this mod? I assume itās best to replace the entire MCPCB and I know Kaidomain and Mountain Electronics both sell triple LH351Ds pre-mounted. Will I just need to buy one of those boards and a solder gun? I apologize for being a total muggle but any information would be much appreciated.
In theory, yes. However, some Kaidomain triple boards need different optics. The ones I have donāt match with Carclo optics.
Who has triple LH351D 4000K 90CRI pre-mounted Carclo compatible is L4P.
Ooopsssā¦ It seems to be SOLDOUT. The BUY button disappeared.
I chuckled at the ānut roasterā comment in the manual. The clip is stronger than I expected which was a nice suprise. And it tailstands, which was also a nice suprise. I have finally found a ramping e-switch light I can live with and actually carry. Kudos to the team here and at TLF for putting this together, and for Lumintop for building it! Iād love to see an 18350 tube, and different finishes aāla the Emisar lights.
You should watch a lot of videos on soldering. Try to get an iron with some good power like 45w or more.
Even though Iām not very good at it, I can say it isnāt that hard. Get a board, pre-mounted, and some thermal paste. It is only two wires that way. Maybe practice a little on something else first.
