In my other thread I had a problem with a Keepower protected battery. Fully charged and fresh off the charger, Turbo would apparently trip the protection circuit and the tail cap had to be loosened and tightened back up to use the battery. After just running it on high for a while, it returned to normal behavior, It was the battery, not the light as it worked perfectly with other batteries.
I know some guys prefer protected batteries, but this light appears to be more reliable with IMR high drain unprotected batteries. Being a true newbie, I can not explain what happened just report it.
The funny thing is, I was using the same battery all day yesterday with no issues, and after letting it run on high for around 15 minutes it started acting normal again. So maybe it was hot internally from just being charged or something.
Here is a comparison between the FT03 and the Convoy L6.
By the way, the FT03 runs a LONG time.
When I ran the above battery down, it was on high or Turbo for over two hours, the battery was still at 3.57 volts, so it had a long way to go.
The distance to the house is probably around 100 feet. You can see how the FT03 is so bright it washes out the wall! Yes, the Convoy looks a little better at that range, due to being less powerful.
This thing is silly bright.
And with the AWT battery it gets silly hot.
Quite an impressive light for under $35. I bought 2 of the SST-40’s in 5000K and 2 of the 50.2’s also. The 50.2’s are awesome. I actually just bought another one in 5700K.
I admit, the FT03 is a very nice budget light, with great specs, but if bought 5 Astroulux FT03’s i would have to come up with a VERY GOOD excuse to my wife
Every shop where they sell flashlights, i walk into the lights section, and my wife says, “like you don’t have a flashlight yet … ”
Yes, for almost every light there is a coupon, or otherwise a 9% discount for BLF members when using banggood ( was it 4BLF ?)
Coupons can be found on the forum or from M4DM4X
Edit, the banner on top just showed a FT03 for 31,99 now, when using code AFT03
That is the view from the front of my house. The minaret is the mosque on the next street. They also own three houses on my block. It is what it is. But frankly, they are better neighbors than the turd next door to me that they bought out.
