Most people don’t have more trouble remembering LMH vs HML; and most people can use a bright light without needing to start off in the brightest mode every single time. They like to avoid needing to :
which sometimes doesn’t work, because the highest mode after going through your hand can be much brighter than a proper ultra low mode.
Not all of them, but some ramping lights and any ramping lights with newer firmware will often come with a simplified UI mode (“muggle mode”) which lobotomizes the light so that people feel better about it. The emisar firmware seems simple enough already; a non-techie just has to know that you hold to change brightness and click to turn on and off.
Useless? I don’t know if you realize this, but there’s plenty of lights that used to and are unable to run at full brightness indefinitely, but they never called that turbo. Without thermal protection, you couldn’t use them for long without checking how hot they were manually and maybe stepping the brightness down if it was too hot. The modern lights with a turbo mode can actually manage that all on their own, and in the q8 for instance, if you put an up to date version of anduril on, you can even put it in turbo mode and have it regulate itself to put out the max brightness that it can without overheating, rather than just stepping down and never stepping back up. And it’ll run for a fair while on turbo with the mass that it’s got. The d4 is a well known example of a light that can go way beyond what’s sustainable, but you might not realize that even ~700 lumens might be too much to sustain, depending. And the fw3a might only make it to 3-400 lumens if you have to have it be able to run like that indefinitely. Personally though, I don’t think many of us only buy lights that are not able to go to a higher brightness than their steady state thermal limit. Almost all lights can get pretty toasty if you let them.
Indeed. If I just want ultra-low to find my way to the bathroom without waking my partner, I have a torch that starts there, and runs off one AA.
Edit: Olight S15
Or if there is a bump in the night, or I am tracking something I may have not shot perfectly (not happened yet, but they can run even with no heart left), at last light, then my 5K or 10K lumen torches serve their purpose, and I like them to turn on full-blast.
Edit: Q8 and MF01 are good for this, once you know the button presses.
There is no one-size-fits all. Horses for courses.
I think memory of previous settings is an over-regarded feature. Not against it, as long as it can be disabled.
I’m a L,M,H kind of guy. I like everything to start in low, I’m still trying to get use to some of these UI’s that need a long press for off. Not a good thing when you slip into bed on moonlight and your wife is a sleep and you do a short press. :laughing: :person_facepalming:
Although I usually just adapt to the UI, one that starts low is probably my favorite…. besides ramping.
‘To me’ moonlight is useless 99.99% of the time & should be hidden, if even included in a larger light. It is OK in a smaller light as long as it is hidden.
But again, these are just my thoughts. I am adaptable if I really like the light…
I’m not a fan of double click for turbo . I’m not an idiot but find myself too many times being blasted with light I never wanted . Lots and lots of features are cool, I like options …I just think this one isn’t clearly thought out .
Anyone with Moonlight-Strobe-High preferences?
I had this kind of weird light few years ago. Looks like it’s actually a defective H-Strobe. It was small plastic aspheric with tacticool style. Bought for about $2 in a bazaar.
I think most people who don’t object to firmware with a complex UI for some other reason don’t have trouble with double click for turbo. Your light’s button might be awkward or bouncing or something; the last time I heard about accidental double clicking it was my grandmother’s worn out old computer mouse.
Just get a Zebralight SC5C, you can program the user interface to anything you like, and have three different programs stored. I love it. quick click for sublumen, long click for medium, which works for outside on a walk, or double click for high. All three are accessible from off. Or change the way you access them to whatever you want. Just wish the light had a better clip (reversable)
I’ve been using a tool for a year + and had the knee jerk reaction to the M/L/H and now it doesn’t bother me in the slightest. I was all ready to driver swap all my lumintop tools and now I kind of like it . I use the heads off the 2xAAA on the single AA bodies and like the smooth head much more than the knurled one and the low is lower on them as well.
Back in the day when ITP or Olight and others used this user interface I was an ardent hater of it .It was probably the green tint and low pwm that those lights had that made me dislike them so much , not the fact it started in medium . A small light starting at 25 lumens and being just a quick click away from 1 lumen isn’t really all that hard to deal with .
I’d agree on a bigger light that would start off brighter like the new Boruit headlamp that starts in a 3rd gear out of 5.That’s a pain to have to throttle it back with stepped ramping .Even then the light still never hits a decent low .
The best driver is the one that allows the user to pick each and every mode and change them on the fly via a ramping .
An older archeon light I have is the only light I’ve ever seen anyone make that does it … If the UI is wrong it’s because you set it that way … Best UI ever .
