Or the YouTube made up word
“Unboxing”
Got it, Thanks for your remind
$260 worth of beautiful!
Klarus ST15R upgrade to 1200lm output, comes with bike mount and diffuser. With USB Charge - K#128Y
• CREE XP-L HD V6 LED with max output up to 1200 lumens
• Compact size, lightweight, comfortable grip, CNC precision machined aluminum reflector with high reflective efficiency, max beam distance up to 260 meters
• Ultra-long runtime, max runtime up to 8.3 days
• Easy and convenient operation, ON/OFF tail switch, side mode switch, each has independent operation
• Strobe, Signal lighting and SOS for emergency uses
• Single click side switch to turn ON/OFF the flashlight during charging for emergency use
• Micro-USB charging port with protective cover, waterproof and dustproof
• Charging current up to 1A, faster charging
• Intelligent Battery Identification Systerm (IBIS): real-time monitoring of charging status to prevent overcharging, ensuring optimum charging status
• Intelligent Thermal Protection System (ITS): monitors internal temperature and adjusts brightness to protect LED and internal components to ensure safety, stability and optimum performance.
• Ring Battery Capacity Indicator: check remaining battery capacity at any time.
• Stainless bezel ring offers protection for crucial components
• Springs at bezel and tail end resist shock and drop damages.
• With mode memory function
• Reverse Polarity Protection eliminates damage from incorrect battery orientation.
• Aerospace Aluminum Alloy body with CNC machining; Mil-spec hard anodizing (HA III); lightweight yet robust construction
Package includes (with original packaging):
Klarus Flashlight
Klarus 18650 2600mAh Rechargeable Battery
USB cable
Bike Mount
Diffuser
Lanyard
Spare O-Ring
Stainless Steel Pocket Clip
