Okay, I’m in the US so I may not be seeing the same exact ads on Amazon.
I see one listing for the SP70. Its from the Sofirn store and has 90 reviews.
They list it as coming with the 5500mAh cells and rated the lights output at 5500 lumen.
So I don’t see anything contradictory to what you received.
Keep in mind that when they bundle products together like a flashlight, batteries and charger to ship to Amazon they can choose whatever combination of parts they want. Then when it comes to sales on their own website they can bundle together whatever parts they want there. So it’s quite possible their website could list the HD batteries and Amazon could be selling it was the non HD batteries. This is perfectly normal.
yes, that’s what im suspecting right now, and that’s what i asked them. because it would kind of makes sense, and its sort of a marketing ploy, where they list only one battery option per size, so u would think they only have one type of this battery, and so if the light comes with batteries, it has to be those. when in fact, they just dont openly sell the shittier ones, and use them to couple with their flashlights.
and ya, it doesnt contradict with what i received, because the amazon listing shows 5500mah, and i received 5500mah, however, the weird circle of confusion and contradiction comes in when amazon sp70 says 5500mah, while sofirn sp70 says PL. now, theoretically, those should be the same batteries, which means mine is PLB, and that sofirn has 2 versions of PLB, 5000 and 5500, but they only sell 5000 separately on their site. alternatively, if mine is not PLB, then it means they only send the 5000 PLB with sp70 orders placed on their site, but everywhere else, amazon, BG, AE., they send the non PLB 5500mah. again, im leaning towards the latter, but we’ll see come sunday night.
Ok, confirmed, 5000mah 26650 is PLB, 5500mah is not, new orders of sp70 should come with 5000mah, but amazon still has old stock, thats why it came with old 5500mah.
Of course this is assuming they are telling me the truth, personally im willing to give them benefit of the doubt
Thanks for the test of the PLB 26650 5000mAh 10A. I got a pair when they were on clearance at Sofirn’s website and only now have a Convoy M3 to use them with!
Lumeniac didn’t directly mention what cell he used for runtime tests in his M3 review, but assuming it was a Liitokala 26650 5000mAh, the runtimes should be just as good with a PLB.
Actually, I don’t think the Sofirn 5000/5500mAh 26650 are always labeled correctly.
Some of the Sofirn “5500mAh” 26650 test a bit closer to 5000mAh, and the battery (the top portion) looks a bit different, indicating it’s likely a different battery.
Although the 5000mAh (based on capacity testing, not the wrapper label) 26650 seems to have a bit lower internal resistance (using a YR1030 battery resistance meter to test)…
i recently got an sp33 v3.0 and the battery is definitely labeled as 5500. Is this a lie? I’m looking to get a spare but if these are not properly labeled then I will look to get 2 if i will see a difference in turbo output as on another post someone mentioned they saw brighter turbo output from an older 21700 4000 sofirn than when a newer 5000 sofirn was used in the same light. to clear up my thread i have been on a bit of a sofirn splurge so i have 3 new lights, 2 using 21700 (c8f and lt1s) and sp33 26650 so…i’m wanting to get the most of the 2 flashlights as i don’t expect nor really want to get much if anything more out of the lantern but who knows. coud it be resistance problem that would cause less output? neither are throwers but i’m not super impressed with them as they both claim around 3500lm turbo output. An expert i’m certainly not but also these are my first lghts with a claim of higher than 1400 so i don’t really have a good personal reference to compare.
It probably is 5500mAh. Keep in mind that the higher the capacity, the lower the amperage, generally speaking. So you need to clarify what your looking for. A very high capacity means it will output a smaller amount of power for a longer time going all the way down to around 2.7 volts. I never run my lights to that low of voltage. Once it hits 3.7v or 3.6v you’ve used the majority of the power and I recharge them. So high capacity is not that big a deal to me.
If your looking for high amperage in a FET based light you would want a lower capacity, high discharge battery. A cell like the Samsung 30T 21700 can output huge amps, but it sacrifices capacity to do it. A Samsung 50E sacrifices high amperage to give higher capacity/run time. Then the Samsung 40T is the in-between cell with a nice mix of amperage and capacity.
The battery manufacturers can mix the chemicals to give a cell the characteristics they want.
I tend to not run the high amperage cells because max output is only at high voltage, like 4.2v and the driver needs to be FET based to take advantage of the amperage. Once you use it a while and the voltage drops a little so does the max output level. Plus they tend to heat up really fast.
I use my Sofirn C8F with a high capacity Samsung 50E cell and my Sofirn SP8 I use the Sofirn 5000mAh to limit turbo and give longer run times. Turbo output is not as extreme compared to high amperage cells, but you can hardly see the difference with your eyes. The difference can be measured, though.
The SP33 V3 measured over 3420 lumens when I tested mine with a Samsung 40T. It certainly won’t be achieving the rated lumens with the included battery, but it’s good enough.
Just remember that the Turbo output is for brief usage. Like a quick blast of light to see further, then you drop the output down to a more normal level for constant use. Don’t expect a constant 3,400 lumen output.
If you need a constant 3,400 lumen output you’d want a bigger light that maybe does 6,000+ Turbo and run it constantly at a lower level.
So I would not get too caught up with max numbers.
Even more to think about, the intensity of the beam is also a consideration. 1,000 lumen spread over a large area looks dim. 1,000 lumen focused in a small area looks bright. So you want the focused beam to be the size you want/need and then you can determine how powerful it needs to be. Luckily, there’s so many good lights on the market you can find what suits your needs.
As far as choosing batteries, I’d get some medium to high capacity cells. Sofirns 5500 are fine for most applications. Just stick to known, tested brands and try to avoid brands that have not been tested. Other good brands are Samsung, Sony, Sanyo, Panasonic, LG and Molicel. (Also buy from reputable sources because fake cells do exist)
If you want to see if a cell has been tested and it’s ratings are accurate, check out HKJ’s tests (use the links at the top of the page) or ask here. https://lygte-info.dk/info/indexBatteriesAndChargers%20UK.html
thanks, it seems i should go with a batt that does a bit of both as been mentioned, as i’m really just trying to get the most out my light but not really for any long time use.
As a bit of an update, I’ve been using my Sofirn SP70 with Sofirn 5000mAh cells almost daily for at least a year now. I’ll run them down to 3.7v or 3.8v at the end of the week and recharge them at a 2 amp rate. They still seem as strong as when they were new. The 5500 and 5000 are the same battery, some just test higher capacity so are labeled 5500. They seem like a solid choice to me as 26650.
Wow, I forgot that none of the big battery companies officially make the 26650 size. That size is a harder to find. So the black Sofirn are good. The Shockli 5500 are good. The other 26650 cells I like aren’t made anymore. Maybe someone else here can suggest more good 26650 cells.
My only concern with this is the extra length. I can’t say for certain, but I’ve convinced myself that over-compressing the tail spring in my EA02 with a Samsung 50E pushed too much current to the FET driven Boost HX and burned a segment. I’ve since been running 18650 GA’s in it.
That’s one LED that should never have been paired with a FET+1 driver though. The only way to confirm that would be measuring the current with a clamp meter on the EA02. I also have the EA02 and never experienced that using a 50E. Wish I could get an mcpcb for the SFT40, but Mateminco don’t exactly play fair when it comes to parts. I used to be a dealer and parts were terribly high.
